icecarver
posted on 11/4/07 at 08:19 AM |
SVA bike clocks on dash ?
Has anybody sva 'd with bike clocks on
their dash.
Question
1. did you sink them in
2. leave them as per the bike ie proud f the dash
Were using standard gsxr clocks
worX
posted on 11/4/07 at 08:25 AM |
SVA'd with Blade clocks, mounted from behind ( ) with adhesive, and then for the actual test, I put rubber "O" Rings round the
Speedo and Rev counter Dials so that the tester is then unable to get his Dome Tester Thingy in to check the 2.5mm interior projection rule...
hth
[img][/img]
zxrlocost
posted on 11/4/07 at 08:52 AM |
if they are within 127mm? of the steering wheel edgde you dont have to meet any requirements
[Edited on 11/4/07 by zxrlocost]
