New Topic New Reply
Author: Subject: Zetec SE Boyz - Alternator advise
seadog
posted on 13/4/07 at 09:51 PM Reply With Quote
Boyz,
Could you advise me on the alternator for the Zetec SE?
I have been told these are controlled via the Ford ECU therefore I will have to look at going for a third party alternator to get round this to enable it to work.
Is this the case???
Many Thanx
[Edited on 13/4/07 by seadog]
takumi
posted on 14/4/07 at 07:50 AM Reply With Quote
I am using a mini Denso alternator, as used on Kubota forklifts, it has 2 outputs one for ignition and one for charging light, and the main power output.
stig mills
posted on 14/4/07 at 10:04 AM Reply With Quote
SE unit is controlled by ECU. If you use it without they put out around 16 volts and destroy batteries quickly. I use donor ECU on the MEV Rocket more often than not, you then get passive anti theft system on your kit if you use donor key and barrel.
ned
posted on 14/4/07 at 09:19 PM Reply With Quote
He doesn't have the ecu, barrel or key.
dogman I may be able to help you out I have a cunning plan
beware, I've got yellow skin
seadog
posted on 15/4/07 at 08:06 AM Reply With Quote
Boyz,
Many Thanx for your advise.
[Edited on 15/4/07 by seadog]
New Topic New Reply
