gixxerpat
posted on 14/4/07 at 10:29 AM |
Urgent sierra u/right Q.
Im sure this has been covered here before somewhere but, i'm using sierra uprights and i need some info on castor angles,im not sure about the
relation between top and bottom b.j's etc..anybody enlighten me.??
stevec
posted on 14/4/07 at 10:34 AM |
Looking down on it it.
Top behind the bottom.
Steve.
posted on 14/4/07 at 12:35 PM |
castor is the angle of a line drawn from upper to lower balljoint, from vertical when viewed from the side. Upper to the rear is the norm.
jambojeef
posted on 14/4/07 at 01:39 PM |
Yep as above - if you aim for the top balljoint to be about 20mm behind the bottom one (with a bit of adjustment either way if poss) you'll not
be far off.
Geoff
gixxerpat
posted on 14/4/07 at 03:27 PM |
Thanx guys ,great help..
