ricklawn
posted on 17/4/07 at 05:36 PM |
HELP
Could anyone please tell me if this fan is a rear fitting fan (pusher) or a front fitting (sucker) it is for a mark 1 cavalier radiator.
Rick
![](/galpreviews/a541687-fan.JPG) ![Rescued attachment fan.JPG](/gallery/a541687-fan.JPG) Rescued attachment fan.JPG
caber
posted on 17/4/07 at 05:40 PM |
Put 12V across it and see which way it blows. Also try reversing polarity this may make it run the other way. You can always mount it with the frame
against the radiator if it is a sucker though it may be worth building a duct for it to make sure the air goes through the core.
Caber![](/images//smilies/smile.gif)
graememk
posted on 17/4/07 at 05:50 PM |
to sucks from behind the rad in the engine bay
ricklawn
posted on 17/4/07 at 05:51 PM |
just started it and it turns clockwise. so will that mean i can fit it in front????
posted on 17/4/07 at 06:28 PM |
no, behind! Clockwise would suck air into the monitor as viewed above. As the blades are largely straight you could reverse the polarity and run it
backwards, in front. However, it might not last as long.
[Edited on 17/4/07 by JoelP]
davrus
posted on 17/4/07 at 06:35 PM |
graememk are you driving to the s.v.a test?
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
stevebubs
posted on 17/4/07 at 08:15 PM |
Not too sure....if you stick a piece of paper close by, which way sucks it closer? That's the bit that should be at the "front" of
the car
graememk
posted on 17/4/07 at 08:26 PM |
no mate i'm chicken, i've borrowed a tailer lol
