New Topic New Reply
Author: Subject: My Rod End is too floppy
RazMan
posted on 18/4/07 at 01:29 PM Reply With Quote
Is there such a thing as a rod end with a very stiff action? I'm thinking about using one for an adjustable mirror so it needs to be either lockable or have a very stiff action. The standard one is too floppy.
Raz
Mr Whippy
posted on 18/4/07 at 01:30 PM Reply With Quote
Fred W B
posted on 18/4/07 at 01:49 PM Reply With Quote
Not that it helps, but I once made the mistake of trying to secure a spherical bearing housing (not a rod end) into a mounting with bearing fit locktite. One drop on the ball surface and it locked solid!
How about a snoop round a camera shop to see what they do with tripods and similar camera mounts?
Fred W B
[Edited on 18/4/07 by Fred W B]
ayoungman
posted on 18/4/07 at 02:56 PM Reply With Quote
Hello Razman, very nice to speak to you at Detling. Liked the car as well, good to see it in the flesh. I bought a rod end from a motor sport supplier a couple of years ago. It was a very tight fit, not at all sloppy. I think it has something to do with the type of seals/construction used. I think Burtons catalogue give these details. I do know that the rod end cost £20, so was quite high specification.
HTH
cheers from Alan
"just like that !"
RazMan
posted on 18/4/07 at 02:57 PM Reply With Quote
Fred, I actually considered this myself but thought that it would just make the rod end unpredictable. My other (less sophisticated) idea was to hit it with a hammer to deform it enough to create a stiff movement.
ayoungman, £20! Nice to meet you too
[Edited on 18-4-07 by RazMan]
Raz
12a RX-7
posted on 18/4/07 at 04:13 PM Reply With Quote
if it's a carbon steel one you could try drilling and tapping it for a locking bolt ? or if it's a small rod end squashing it a little in big vice might tweak it enough to grip the centre ?
New Topic New Reply
