RichardK
posted on 19/4/07 at 07:40 PM |
Premier Wiring's Headlights
Is anyone using these from Premier Wiring? Any Good?
110mm bottom mount headlamp £75.00 pair
Very compact headlamp unit e-marked takes H4 halogen bulb c/w s/lt.
Satin black.
Chrome.
Carbon fibre look a like.
Rich
Gallery updated 11/01/2011
jambojeef
posted on 19/4/07 at 07:50 PM |
As I understand the manual - you can have dip down headlights if the dipped beam falls within markings as laid out in the manual?
Can anyone confirm thats the case?!
Hope i havent mislead you if Im wrong, but the 2CV headlights I have fitted have passed on others cars and they only dip down.
Hope thats of some use?!
Geoff
cossiebri
posted on 19/4/07 at 08:05 PM |
They look the same as mine, I got them from rally design. Hope they are ok for mot! not wired them in yet
If it doesn't fit MODIFY it!!
Cheers BriF
RichardK
posted on 19/4/07 at 08:25 PM |
Think I'll have to give them a ring to confirm then. Unless someone else confirms beforehand that is.
Rich
Hammerhead
posted on 19/4/07 at 09:09 PM |
i'm having a similar problem. I want to use bike lights, but even though the ones i have are uk spec, they only dip down not down and left. So
to help matters I have bought aftermarket ford focus angel eyes that are meant to dip doen and left, I am going to cut these up and graft them to the
bike housings i have.......they haven't arrived yet so hopefully they will be ok. Will post pics if it works out
