Author: Subject: suspension bolts
adrian
posted on 23/4/07 at 06:40 PM Reply With Quote
suspension bolts
Hi just been reading through the sva manual- it says suspension bolts should have strength rating of 8.8 or equivalent
mine have three lines marked on them? (they came with the kit)
does anyone know if these are ok?
gulf zxr
posted on 23/4/07 at 06:43 PM Reply With Quote
As far as I know they should be marked with the correct grade i.e. 8.8 for SVA. If you get stuck or are not sure I have a spare set of 26 M10x70mm bolts (grade 8.8) with nylocks and 52 10mm washers all in BZP finish.
If your interested you can have them for £10.00 + postage
Jason
zxrlocost
posted on 23/4/07 at 06:52 PM Reply With Quote
three marks is fine although your SVA man might not know this so print it off the internet somewhere if you can
adrian
posted on 23/4/07 at 06:54 PM Reply With Quote
thanks gulf for the offer!
and thanks zxr for a great solution, i'll scanvange the interweb now!
tks
posted on 23/4/07 at 07:06 PM Reply With Quote
it could be the brand logo..
if nothing is stated its poor quality..
Tks
Tralfaz
posted on 23/4/07 at 07:32 PM Reply With Quote
Three lines is Grade 5 here in the states. I would think (hope) markings are universal.
Be dangerous otherwise.....
I would say replace with a high quality Grade 8 or better.
T
[Edited on 23/4/07 by Tralfaz]
indykid
posted on 23/4/07 at 07:34 PM Reply With Quote
Tks
or they're imperial........
have a look on wikipedia. pehaps not the most reliable resource, but still
here
hth
tom
Wadders
posted on 23/4/07 at 08:39 PM Reply With Quote
Spot on Tom, more than likely 1/2" UNF, AFAIK 3 lines is equivelent to 8.8 in metric.
Al.
ayoungman
posted on 23/4/07 at 09:49 PM Reply With Quote
spot on, definately imperial markings. half in bolts. search the forum, i remember a thread from a couple of years ago on bolt markings that was useful.
iiyama
posted on 25/4/07 at 06:01 PM Reply With Quote
Ive used Ti bolts everywhere. Never gave it a thought I would have to prove bolt strength. Ill have to get some paperwork for SVA time then!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
