New Topic New Reply
Author: Subject: Chassis height
andrewturner
posted on 27/4/07 at 07:49 PM Reply With Quote
Chassis height
I am busy building a Mcsorley chassis, I was using the std book drawings, but wanted to add a bit of height so that I could fit a 20v 4age motor without having problems with sumps and holes in the bonnet. I have started by adding 50mm in height to the engine bay and cockpit area but my concern now is that will my car look odd if I keep the bulkhead the same height. I have checked the Mcsorley 7+442 drawings and the rear bulkhead is 533 high which is the same as the book chassis.
Do I infact need to add the height for the 20v 4age.
Ivan
posted on 27/4/07 at 08:30 PM Reply With Quote
It's difficult to say what the extra height will look like - I added 1" by using 38X25 tubes for the top & bottom rails and think it looks ok - means I can reduce the scuttle height by 1" which makes the car look a lot lower.
One thing you could try is to slant the upper member down towards the back an inch or two in the cockpit which will help to visually disguise the height and looks more like the original 7 if memory serves me right.
Chippy
posted on 27/4/07 at 11:13 PM Reply With Quote
I made my chassis one inch higher front, and back, but ran the tube on the cockpit side down one inch, (from front to back). I did mine because the V6 is a bloody great big engine. As you can see from my avatar doesn't look too bad. Ray
kb58
posted on 28/4/07 at 12:04 AM Reply With Quote
It's subjective. If you like the way it looks, do it. Many people don't like how 7's look - that hasn't stopped anyone here.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
New Topic New Reply
