Author: Subject: Oil Pressure....... how much???
MOz
posted on 30/4/07 at 12:57 PM Reply With Quote
Recently changed the clutch springs and oil on the IndyBird. Went from fully synth to semi synth oil and followed Sean's advice and filled to just over the max mark on the dipstick once the accusump had been fully charged.
It now runs much better (clutchwise) but I have found a film of oil on the rightside of the engine bay and suspect it has been blowing out the breather (which I have no idea of where it is on a Blackbird engine......).
The oil pressure guage seems to be reading higher than it did before. Really pushing it, it rises as high as 80 PSI, and general bumbling around reads 60 PSI. At tickover it reads 25-30 now but was lower than that on fully synth thru out the rev range.
I know semi synth is thicker than fully synth, but can this be enough to raise the engine oil pressure??? Also, is having too much pressure a bad thing (I guess it is) and if so how much is too much????
Again, nieve worrying but worry it is!
MOz
Jon Ison
posted on 30/4/07 at 01:12 PM Reply With Quote
Thats the sort of pressure I saw on my Bird on semi oil and accusump.
MOz
posted on 30/4/07 at 01:27 PM Reply With Quote
Presume you didn't miss out the sentence: "just before it blew up....." did you?????
MOz
Jon Ison
posted on 30/4/07 at 01:47 PM Reply With Quote
MOz
It was called the cat, lost sump plug survived, blew an oil cooler hose on track, caught fire and still lives on.
INDY BIRD
posted on 30/4/07 at 09:28 PM Reply With Quote
Hi Moz
Oil pressure sounds about wright to me it did used to run around 75 psi and 80 at full chat.
would be around 55-60 on normal runs and tickover 25 psi,
not too much change there the pressure relief vallve is woeking ok so should be no probs.
glad the cluth is better more power to the road now ????????????
not sure on the breather though just double check oil levels and see if it settles at some point.
Good luck
Hope she is still running good may see you at stoneleigh if your there monday.
Sean
DIY Si
posted on 30/4/07 at 10:01 PM Reply With Quote
There isn't a breather on the drivers side. I had soemthing similar on mine, it turned out I hadn't done the filler plug up fully and as the clutch is behind it, is was throwing out a little oil. Also check the dipstick is fully done up.
Sun Tzu, The Art of War
G.Man
posted on 1/5/07 at 12:24 AM Reply With Quote
My ZX12r Blew about a litre of hot oil out into the floor pan this weekend..
Was rather disturbed about it at 190km/h but further investigation revealed it was the gearbox breather and not a blown oil line.. this pipe is now routed into the top of the dry sump rez
Opinions are like backsides..
