Author: Subject: will i get magnets for speedo at Stoneleigh??
mad dad
posted on 1/5/07 at 01:50 PM Reply With Quote
As above really i need to get some for my speedo sensor/propshaft and wondered if anyone knows if i will be able to get some at the Show before i go to e bay??? Cheers Andy
nib1980
posted on 1/5/07 at 02:09 PM Reply With Quote
Have you not tried maplins they usually have some tha will do the job
mad dad
posted on 1/5/07 at 02:14 PM Reply With Quote
just thought i would see if i could pick some up when at the show if not will try them, Cheers
cryoman1965
posted on 1/5/07 at 02:16 PM Reply With Quote
I hope so as mine flew off Sunday. From 105 mph to 0 in less than a second.
N
mike smith1
posted on 1/5/07 at 02:27 PM Reply With Quote
http://emagnetsuk.com/index.asp?function=DISPLAYCAT&catid=48
E magnets uk this is what people have used in the past, are you using a speedo healer?
Mike
[Edited on 1/5/07 by mike smith1]
James
posted on 1/5/07 at 02:32 PM Reply With Quote
Raid a fridge at the tip?
Seem to remember Conrod used some from a fridge for one of his cars.
James
roadrunner
posted on 1/5/07 at 06:12 PM Reply With Quote
Do you really need magnets,i remember someone saying you dont have to use them.
posted on 1/5/07 at 06:45 PM Reply With Quote
Didn't use magnets on mine. Just fit the sensor to pick up on the prop bolts but make sure the heads are set to the same relative position . Been OK for 2 years and was accurate for SVA.
theconrodkid
posted on 1/5/07 at 06:46 PM Reply With Quote
if they are the "rare earth" stronger than a strong thing on steroids maplins do them,if you need weak southern spec ones,raid the fridge door
who cares who wins
pass the pork pies
roadrunner
posted on 1/5/07 at 06:49 PM Reply With Quote
How many bolts did it need Rusty Nuts, and obviously, you need them equally spaced.
mark chandler
posted on 1/5/07 at 07:08 PM Reply With Quote
rrv clocks need 9 magnets with 185/60 13 wheels and 3.65 diff if placed on prop, no speedo healer required.
Rgds Mark
roadrunner
posted on 1/5/07 at 07:22 PM Reply With Quote
I have zx9 digi clocks, with 215/40 17" wheels, how many do you think, oh, and a 3.62 diff.
mad dad
posted on 3/5/07 at 04:37 PM Reply With Quote
fitting blackbird clocks (as below) with a RRV blade engine!!!! and i thought this would be easy!! have been away which is why i have not replied earlier thanks everyone....Andy Rescued attachment New Dash 22804.JPG
