New Topic New Reply
Author: Subject: How can I Change "Q" to fit my engine
andrewturner
posted on 1/5/07 at 06:31 PM Reply With Quote
DRC INDY 7
posted on 1/5/07 at 06:40 PM Reply With Quote
Puddle Dodgers Club
cadebytiger
posted on 1/5/07 at 06:42 PM Reply With Quote
I'm sure you all know if you look deep down inside yourselves
andrewturner
posted on 1/5/07 at 06:44 PM Reply With Quote
"Q" the cross member in the Book Chassis
meany
posted on 1/5/07 at 06:49 PM Reply With Quote
which engine are you planning to use?
indykid
posted on 1/5/07 at 06:50 PM Reply With Quote
maybe some slightly more direct questions....
what engine?
what gearbox?
tom
zxrlocost
posted on 1/5/07 at 07:05 PM Reply With Quote
dude your gonna have to type a bit more in the BIG text box!
[Edited on 1/5/07 by zxrlocost]
andrewturner
posted on 1/5/07 at 07:49 PM Reply With Quote
I am fiting a Toyota 4AGE 20v with the w55 box and want to get the whole thing further back 150mm so I need to cut out the section marked "Q" in the book chassis how should I do this?
posted on 1/5/07 at 07:51 PM Reply With Quote
thats quite an important tube, why do you need the engine so far back?]
you would have to brace P to make up for it. Work out what has to go, fit the engine, and see what you can add to make up for it.
[Edited on 1/5/07 by JoelP]
posted on 1/5/07 at 07:55 PM Reply With Quote
indykid
posted on 1/5/07 at 08:05 PM Reply With Quote
what about making the middle of Q into an X between the tops of the H tubes and P?
you still don't get a straight load path, as you would with Q, but from a 'looking at it' point of view, it would appear to work.
tom
indykid
posted on 1/5/07 at 08:06 PM Reply With Quote
Can i ask if its such an important tube, that Mac #1 see fit to split is right in the middle and effectively have two at the ends of each footwell ?
thinking about it, so do MK....
tom
posted on 1/5/07 at 08:38 PM Reply With Quote
You'd have to ask MAC#1 that im afraid (or MK).
I did edit to point out that anything can be done if you want, however there is no point making the engine bay bigger than necessary. If you want to move the engine that far back you may as well redesign the whole front to suit it.
New Topic New Reply
