graememk
posted on 2/5/07 at 10:41 PM |
Immobiliser
what have others put on there kits ?
Andy from the MK Owners club asked me what i was using the other night, and to be honest i hadnt thought about it. i've had a quick look on ebay
but didnt see anything that got my eye.
nitram38
posted on 2/5/07 at 11:10 PM |
I have a Toad Cat II thatcham transponder immobiliser. Only £40 on ebay. You will need it either professionally fitted or signed off by a certified
auto electrician if you want the benefit of cheaper insurance.
NeilP
posted on 2/5/07 at 11:31 PM |
My donor had an old Scorpion set up on it which was in perfectly good order - plumbed it in to kill the ign feed to the ecu and the feed to the
starter pack...
Any immobiliser is going to offer you a damn sight more protection than a steering lock and you should underestimate the 'Feck Off' factor
of a blinking red led on your dash. My insurers set out a long list of conditions in terms of any additional security product making a substantial
difference to the premium but was always going to put something on...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Paradoxia0
posted on 3/5/07 at 12:05 AM |
I got a Toad Thatcham Cat II transponder off eBay too for about £40.
After a bit of headscrating the cables to cut with it became obvious so I fitted it myself. When I get the car SVA's I'll get it certified
by a local fitter to get cheaper insurance.
It was certainly worth fitting for my piece of mind alone!
Mark
There is no replacement for displacement...
flak monkey
posted on 3/5/07 at 07:11 AM |
I bought one of these:
Clic
ky
Doddle to fit. But bear in mind if you fit it yourself it wont knock you any money off your insurance as it wont be certified.
Sera
http://www.motosera.com
RazMan
posted on 3/5/07 at 10:41 AM |
Flak, that immobilisor looks as though there is only one or two connections to make - is it really that simple?
Raz
flak monkey
posted on 3/5/07 at 10:45 AM |
The pics been simplified a touch.
Theres an earth, permanent live, switched live then all of the other wires just tap into existing circuits on the car. eg starter solenoid feed, coil
feed, fuel pump feed etc. Then theres a pre-terminated connection for both the RFID loop and the LED status light. Theres lots of wires, but its very
very simple to connect up and it comes with easy instructions. Its also got a door open trigger too, but you can just leave it disconnected if you
dont have doors, like most of us ![](/images//smilies/tongue.gif) as it auto arms after 20secs once the ignition is turned off.
It lets you cut off up to 3 different circuits, each with 2 seperate sets of wires, just to confuse any potential theif even more.
[Edited on 3/5/07 by flak monkey]
Sera
cossiebri
posted on 3/5/07 at 05:24 PM |
I've also got the same as flak,just haven't fitted it yet (got to get it started first!)
had a quick look at the instructions,was going to fit a switch to earth to replicate the door trigger
If it doesn't fit MODIFY it!!
Cheers BriF
flak monkey
posted on 3/5/07 at 05:44 PM |
No need for a switch to replicate door trigger. Just leave it disconnected.
Sera
Paradoxia0
posted on 3/5/07 at 05:51 PM |
My Toad is the same.
There is a cable for a door plunger switch (I was going to add a dask switch to earth for this) that turns the imobiliser into "read" mode
to scan for transponders. I discovered that as soon as the ignition went on it went into read mode anyhow so it isn't needed.
Works a treat too! The following day when I went out with the other key without the transpoder on it took me ages to realise why nothing was happening
when I turned the key (yes I am a muppet at times ![](/images//smilies/bigsmile.gif)
RoadkillUK
posted on 3/5/07 at 06:14 PM |
I used one of these, I modded it a little so it can't be activited while the ignition is on.
HERE
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
