Author: Subject: How do I join all these bits then?
Mark Allanson
posted on 6/8/03 at 03:22 PM Reply With Quote
I am planning to use sierra pedals, and want to know how others have connected the brake pedal to the master cylinder?
I have removed all the bits from the servo and my first impressions are to bore out and thread the longer rod and then externally thread the smaller one to make it length adjustable - is there an easier/better/safer way of doing it?
What is the optimimal distance of the pedals from the floor, I know foot size will probably determine this, but has anyone regretted a pedal setting and will allow me to benefit from their mistake!
Thanks in anticipation
James
posted on 6/8/03 at 04:25 PM Reply With Quote
Mark
I've just finished mine using Sierra and Micra bits but unfortunately my parents have had the indecency to take their camera with them on holiday!
I'll see if I can borrow one!
James
James
posted on 6/8/03 at 04:27 PM Reply With Quote
P.S. Are you going for top or floor mount pedals? And/or were you planning on using the Sierra ones or making new?
James
Mark Allanson
posted on 6/8/03 at 05:28 PM Reply With Quote
I have had an exiting day (need to get out more perhaps?). I was worried about the pedals but it has gone together like Lego.
I have taken out the bushes and cut them in half, to make the pedals closer together, now 50mm gap between the pedal rubbers. This means the pedals will fit between the steering column and the tranny tunnel Rescued attachment PedalsCloser.jpg
Mark Allanson
posted on 6/8/03 at 05:35 PM Reply With Quote
I have also used the primary rod to actuate the master cylinder, to stop it falling out I have fitted a bolt to take the strain off the brake lamp switch. This gives me 33mm of travel for the piston, which looks right looking at the old marks on the rod.
This has gone together so smoothly, I think I must have overlooked something. Please tell me now before I weld it all in at the weekend! Rescued attachment PedalsShaft.jpg
Mark Allanson
posted on 6/8/03 at 05:39 PM Reply With Quote
Everything together, too simple to be OK? Rescued attachment Pedals&Cylinder.jpg
posted on 6/8/03 at 06:37 PM Reply With Quote
looking at that, its just dawned on me that the brake switch is missing on mine. is that where its meant to go?
must say it looks a lot better than mine. If the brake pedal is adjustable (i'm gonna do trial and error) and the gaps are SVA good, and mountings and steering all work, what can possibly go wrong?!
remember you need the right tilt on the cylinder and fluid container...
[Edited on 6/8/03 by JoelP]
chrisg
posted on 6/8/03 at 06:55 PM Reply With Quote
Looking at your piccy's brought back memories of trying to set those evil "quadrant" type clutch pedals (the yellow bit) they've had some nails and skin off me! Can't understand why Ford ditched the old adjuster and lock nut (on the other end of the cable) simplicity it's self. Bloody so called self adjusters never work any way.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stats
posted on 9/8/03 at 08:00 PM Reply With Quote
Ihave just taken the pedal assmbly out of my sierra and know what you mean about skin and nails
Has anybody used the servo off the the sierra??
Stats
posted on 9/8/03 at 09:34 PM Reply With Quote
i chopped the servo up out of curiosity! many reckon it isnt needed, the book as well, so im just going with the crowd! when you get it out you realise the clutch has something you can press to get more slack! I nearly ended up sawing the cable off....
Northy
posted on 12/8/03 at 06:48 PM Reply With Quote
Mark,
Looks very similar to how its done on the Avon. Not sure if thats a good thing or a bad thing
Tiger give you a machined rod that fits between the master cylinder and pedal, and does the same as yours.
On the Avon, you have to shorten and straighten the pedals, but I guess you knew that didn't you?
Graham
Catching up after my Honeymoon
Graham
Mark Allanson
posted on 12/8/03 at 06:58 PM Reply With Quote
I have not had to shorten the pedals at all, I have altered the spacing and relocated the clutch cable tube so it is still in line with the quadrant. I have altered the angle of the U shape of the clutch pedal so it does not foul the tranny tunnel - looks like grew there now
Chris_R
posted on 9/7/04 at 06:20 PM Reply With Quote
what's everyone done about the stop for the self adjuster behind the clutch pedal? Surely if the pedal moves that needs to move too, or does it?
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Mark Allanson
posted on 9/7/04 at 07:22 PM Reply With Quote
Chris_R
posted on 9/7/04 at 07:55 PM Reply With Quote
I like the idea of not having to straighten the pedals. Does it all still mate up ok? The self adjuster I mean. Oh, and when you say you cut the bushes in half, is that the one on the clutch and the brake pedal, or just the clutch?
Chris.
[Edited on 9/7/04 by Chris_R]
Mark Allanson
posted on 9/7/04 at 09:31 PM Reply With Quote
You have to keep the brake pedal in its original position so it still mates up with the master cylinder. I cut the clutch one in half and half either side of the pedal to move the clutch pedat about 20mm closer to the brake Rescued attachment Clutch Move.jpg
