Author: Subject: Vauxhall 2.2ltr?
SparkyPups
posted on 6/8/03 at 04:18 PM Reply With Quote
Vauxhall 2.2ltr?
I have been offered a 2.2 ltr engine from a 2002 vectra. The questions are
can I use it?
does it use the same bellhousing as the xe for a T9?
what about manifolds?
is the head worth getting by itself to fit to a short block xe?
Sparky
edit: Its for an upgrade so engine age etc is immaterial
[Edited on 6/8/03 by SparkyPups]
david walker
posted on 6/8/03 at 07:55 PM Reply With Quote
I think you'll find this is a chain driven OHC unit, unlike the 2.2 Frontera which is a belt driven Ecotec unit.
Given all that, you obviously can't swop heads etc. As to if the engine is OK, it probably is but is probably on the large side. You would be better with an XE though IMO.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
ned
posted on 7/8/03 at 08:49 AM Reply With Quote
I'd doubt the standard injection system would fit, and guessing you'd be hard pushed to find a carb manifold for that engine, direct to head throttle bodies are an option, though will be expensive...
Ned.
beware, I've got yellow skin
