millemg
posted on 9/5/07 at 04:10 PM |
3 questions - R1 - Fuel pump - diff
Firsly, have I got my Bosch pump the right way round for flow, and also, where is the best place for an inline filter. I hoped it can go up front near
the engine for easy access ?
Next. I noticed on one side of my diff, there is a small bracket bolted here, but is missing from this side, is it important ?
And lastly........Engine mounting bolts on a 5pw R1, they look like 10mm but seem to have a finer thread than M10 , anybody know what they are?
Cheers in advance
[Edited on 9/5/07 by millemg]
[Edited on 10/5/07 by millemg]
flak monkey
posted on 9/5/07 at 04:13 PM |
If the mounting bolts on most bike engines are anything to go by they will be M10x1.25 pitch.
The diff should have a little y-shaped plate which locks the bearing retaining/adjustment ring (the castellated bit). You should be able to knock one
up out of a bit of plate.
No idea about pump.
Sera
http://www.motosera.com
millemg
posted on 9/5/07 at 04:15 PM |
Cheers, you win the first goldfish
Pump answer gets the cuddly toy..!!!!!!
zxrlocost
posted on 9/5/07 at 04:26 PM |
hi mate the diff one doesnt look important
the r1 threads are very fine and you need longer bolts to go through your engine mounts
I think I have a load left as there quite expensive
ill have a look
ta chris
u2u me to remind me
millemg
posted on 9/5/07 at 04:28 PM |
ill have a look
ta chris
u2u me to remind me
You have a U2U to remind you
chockymonster
posted on 9/5/07 at 10:42 PM |
What type of pump is that?
As for the mounts, I used M10 fine bolts through the cradle into the the engine, they weren't long bolts.
The bottom bolt that's on the chassis rail I drilled and tapped to M12 coarse.
I used 2 bolts, one from each side.
millemg
posted on 10/5/07 at 06:31 AM |
It's a Bosch electric pump from an Alfa V6 injection, so I think it will cope I just don't know which way it flows.
chockymonster
posted on 10/5/07 at 08:41 AM |
Which side is the high pressure fitting
Mine is on the same end as the power contacts.
12mm connector to tank, 8mm connector to fuel pipe
