Author: Subject: Brake servos
jon_boy
posted on 21/5/07 at 12:29 PM Reply With Quote
Brake servos
Having discovered the servo on my scimitar is pooped and i new one from Graham Walker (scimitar specialist) is £160, im wondering is this a lot of money and does anywhere do them cheaper. Im basically looking for a stand alone servo where the pipe goes from the master cylinder into the servo and out the other side. If that makes sense.cheers for any help, Jon
x_flow57
posted on 21/5/07 at 12:35 PM Reply With Quote
You could try Clive at Manvers Triumph, if I remember correctly the Scimitar is the same as the TR6 set up, I bought a servo from him recently, sensibly priced.
01359 244417
They are also usefull for Herald metalastic or polly bushes.
Mention my name
Nick
mookaloid
posted on 21/5/07 at 12:37 PM Reply With Quote
If I recall from my Scimitar days there are two types, One can be reconditioned and one can't.
Maybe yours is the type that can be repaired?
If not then the solution was to replace with an aftermarket servo which could be plumbed in in a similar position to the original.
I notice that europa sell one for £232 so the £160 doesn't sound too bad to me.
Mark
posted on 21/5/07 at 01:48 PM Reply With Quote
If it is a Lockheed servo they are easy to rebuild, Girling ones are much more difficult.
You can use any Lockheed or Girling remote relay type servo
Rootes Arrow range (Hillman Hunter......) are a good source they have the Lockheed type.
russbost
posted on 21/5/07 at 03:42 PM Reply With Quote
Have a feeling car builder solutions do one? Can't remember how much tho'
mookaloid
posted on 21/5/07 at 03:44 PM Reply With Quote
I had that feeling but couldn't spot it on their web site
davidwag
posted on 21/5/07 at 05:18 PM Reply With Quote
Rimmer bros do a univerval fit remote one for £146.88 inc VAT part no.RH5272
jon_boy
posted on 21/5/07 at 06:33 PM Reply With Quote
Thank you all soo much for the rapid help. Looks like im just going to have to save up then, as mine is pooped and is the early non refurbishable one. Thanks a lot though people!!
posted on 21/5/07 at 06:45 PM Reply With Quote
Its the early Girling ones that can be repaired -- but it requires care.
Even the later Girling types the hydrualic bits can be fixed but the vacumm side is a sealed unit.
Lockkheed remote servos can be got for 115 pounds new.
