mattgriffiths2002
posted on 22/5/07 at 02:08 PM |
De Dion Rear Axle Setup??
Hi Folks,
I have a De Dion axle for the rear setup as in the picture although im not sure as to what hubs or driveshafts I need and how it all fits together. So
far, I have a Sierra LSD for bolt in shafts which I shall use with it but no drivehafts or hubs as I don't know what I need. If anyone knows then
let me know which parts I need to get for it,
Matt
![](/galpreviews/a562566-Image035.jpg) ![Rescued attachment Image035.jpg](/gallery/a562566-Image035.jpg) Rescued attachment Image035.jpg
mangogrooveworkshop
posted on 22/5/07 at 02:14 PM |
Welcome to the mad house......
Dedion no probs this is what it should look like
Image deleted by owner
Its all standard Sierra and that comes from an Early MK
[Edited on 22-5-07 by mangogrooveworkshop]
ecosse
posted on 22/5/07 at 02:29 PM |
You might have problems using the bolt in driveshafts as they are a fair bit bigger than the push in ones and won't fit most dedions, but if you
measure the diameter of the hub tube it will need to be larger than 100mm internal diameter for them to fit, otherwise either try and find a push in
diff or attempt to join push in shafts to bolt type flanges (it has been done b4)
Alex
mattgriffiths2002
posted on 22/5/07 at 02:32 PM |
Thanks for that, I have a much better idea now. The only thing is that my diff is for bolt in shafts meant for disc brakes i think so will these
shafts still work or do they have to be the push in ones for the drum brakes?
So, anyhow, I need to get standard sierra hubs and driveshafts from an early mark. Do you know what marks or age?
Matt
mangogrooveworkshop
posted on 22/5/07 at 05:41 PM |
Those are from a k reg but they are mostly the same
bobster
posted on 22/5/07 at 07:28 PM |
does anyone know where I can buy a de dion rear axle?
flak monkey
posted on 22/5/07 at 07:29 PM |
GTS sell them, and are the only manufacturer that has a solely de dion based car as far as I know.
Sera
http://www.motosera.com
mangogrooveworkshop
MK or GTS
mangogrooveworkshop
posted on 22/5/07 at 07:31 PM |
http://www.gtscougar.freeserve.co.uk/
http://mksportscars.co.uk
bobster
posted on 23/5/07 at 10:35 AM |
thanks. MK are not doing them anymore and I can't get through to GTS. I have tried the main line number and left several messages and sent
emails but no reply. Does anyone know how to get hold of them?
flak monkey
posted on 23/5/07 at 10:37 AM |
The on goung GTS saga continues....
You just need to keep trying, Darrens not replying to my emails either at the moment.
Sera
