Author: Subject: starter switch
milton
posted on 31/5/07 at 09:56 PM Reply With Quote
starter switch
bought a starter switch panel from Car Builder Solutions the one with the ign light push switch and doomsday plus relay switch very nice but no wireing diagram any one fitted one and could supply a diagram I am hopeless when it comes to electrics
The Great Fandango
posted on 31/5/07 at 11:27 PM Reply With Quote
I bought mine 6 months ago and still haven't bothered fitting it due to lack of wiring diagram...
From memory (as it's in the depths of the garage) mine came with about 3 relays so was unsure (i) if they were all needed and (ii) whether the switch actually had an LED in it.
Poor show from CBS if you ask me.
[Edited on 31/5/07 by The Great Fandango]
He Who Dies With The Most Toys Dies The Happiest
posted on 1/6/07 at 07:54 AM Reply With Quote
Surely all it needs is 10 minutes with a test meter, or even with a bulb and battery, to sort out which connection does what?
The average ignition switch does just 2 things - switches on the 12v to the car's loom, and provides a 12v supply to the starter solenoid. I suspect that the relay is used to drive the solenoid, thus protecting the push button.
If there's a lamp involved, then once the switch connections are sorted then a few minutes playing with a battery should identify its connections.
Alternatively, have you tried asking CBS for a wiring diagram?
DJ
milton
posted on 1/6/07 at 08:32 AM Reply With Quote
switch
thanks for that I am going to try CBS .
rusty
posted on 1/6/07 at 10:24 AM Reply With Quote
I can draw a diagram of hos I used a similar system if you require it.
rusty
posted on 1/6/07 at 10:42 AM Reply With Quote
Did one anyway
The relay that isolates the aux curcuits during cranking is optional just takes some load of the battery.
milton
posted on 1/6/07 at 03:37 PM Reply With Quote
starter panel
thanks for that but I only have one relay will try to sort it out have spoken to cbs.who say the will try to get one drawn and send to me if they do I will try to post on this site
rusty
posted on 4/6/07 at 12:38 PM Reply With Quote
If you want one for a single relay then I can also do that.
rusty
posted on 5/6/07 at 06:56 PM Reply With Quote
I'm 99% sure the relay pin numbers are correct, drawing shows a fused relay but omit the fuse if yours does not have one
Forgot the light just connect that to the ignition feed showen blue and ground.
[Edited on 5/6/07 by rusty]
milton
posted on 6/6/07 at 08:55 PM Reply With Quote
starter
cheers will print and file.
