New Topic New Reply
Author: Subject: Welding round section tube end to end
Matthew_1
posted on 14/8/03 at 10:52 PM Reply With Quote
Does anyone know if its practical/recommended to butt weld round tube end to end. Seems pretty ok to me, but just wanted to make sure!
posted on 14/8/03 at 11:43 PM Reply With Quote
Best to use an insert if you weld anything end to end.
yours, Pete.
carcentric
posted on 15/8/03 at 12:36 AM Reply With Quote
. . . with holes drilled in the outer tubes so you can also fill in rosettes an inch or two above and below the joint.
M D "Doc" Nugent
http://www.carcentric.com
iceT
Junior Builder
Posts 30
Registered 1/7/03
Member Is Offline
Photo Archive Go!
Building: R1 Locost based on book chassis but with IRS
posted on 15/8/03 at 04:12 AM Reply With Quote
Petef,
Does this apply to RHS as well? Is it advisable to use inserts or is it ok to butt well end to end for RHS? No u got me wondering...
blueshift
posted on 15/8/03 at 04:58 AM Reply With Quote
with ref. tube, I have read that it's also a good idea to cut the tubes at an angle, or cut two angles (a vee shape) so the weld is longer and stronger. That was for welding a smaller tube into a larger one, would think it applies though.
twentyover
posted on 15/8/03 at 06:43 AM Reply With Quote
I think that aircraft practice (and Carol Smith's books suggest a sleeve over the OD of the tubes, and a scarf jount of V cut on the end of the sleeve. IIRC, you weld each of the tubes to the sleeve, and do not weld them to each other
New Topic New Reply
