robbydee
posted on 3/6/07 at 09:35 PM |
Diff problems?
Just jacked the rear of the car to check the diff, turned one of the rear wheels and the opposite side never moved..
swap sides and turned the non moving wheel (not tight or Stiff) and the opposite turned the opposite way slowly... and not consistent... is this
normal.. or should i prepare a spare....
darrens
posted on 3/6/07 at 09:43 PM |
is it an lsd
robbydee
posted on 3/6/07 at 09:46 PM |
i really dont know that is what i was trying to find out..
i do know its a 3.38. non bolted
hillbillyracer
posted on 3/6/07 at 09:54 PM |
Well if you're turning a wheel then either the other side wheel or the propshaft has to turn too or something is badly broken!
andylancaster3000
posted on 3/6/07 at 09:57 PM |
You'll probably find its just spinning the prop rather than driving across the diff. Shove it in gear and try again!
graememk
posted on 3/6/07 at 10:02 PM |
was the car in gear or not ?
robbydee
posted on 3/6/07 at 10:05 PM |
was out of gear...will try again..later..
