Jici
posted on 7/6/07 at 12:18 PM |
MK Indy ZX9R - Advice
Hi there,
Would any of you have an opinion on the following car ?
http://www.pistonheads.co.uk/sales/159222.htm
Trying to buy from Belgium I often don't have the time to see the car before buying it. Therefore any external opinion would be great.
Thanks for your help.
Mad Dave
posted on 7/6/07 at 01:18 PM |
If you can get to the Newark Kit Car Show in just over a week I'm sure you will see the car there.
Jici
posted on 7/6/07 at 01:42 PM |
Very good suggestion !
I guess it is a good opportunity to compare different models and offers in one time.
Unfortunately I will not be able to attend that one. Is there somewhere a website that list all the comparable Kit car Show in the UK ?
Thanks a lot
Howlor
posted on 7/6/07 at 01:43 PM |
As Dave has said above. If you could visit Newark you could use the Ferry into Hull. If the guy isn't going to Newark then you would pass
Doncaster anyway when travelling from Hull to Newark.
The journey is very simple from Hull ferry terminal as you just take the A63 which then turns into the M62, then the M18, then the A1 right to Newark
and the show is 2 mins from the A1 road. Very easy and will take you about 1.30hr.
You should see many cars for sale so you can compare them.
Howlor
posted on 7/6/07 at 01:44 PM |
Oops too late posting so doesn't read right now!
You could try Harrogate. This is once again reasonably close if you were to travel on the ferry.
posted on 7/6/07 at 04:33 PM |
Steve, Harrogate has been cancelled for 2007 IIRC.
Phil
