Author: Subject: Cortina brake disk locktabs
chockymonster
posted on 20/6/07 at 03:20 PM Reply With Quote
Guys,
One of the locktabs on my cortina hubs has lost both of it's locking bits which is obviously bad.
A kind soul has suggested using spring washers instead, now I hate spring washers with a passion so I'm not sure what to use. Would blue or red loctite be ok?
My local ford dealer are next to useless and can't supply replacement tabs and have suggested spring washers as that's what Ford used late on in the life of the cortina.
posted on 20/6/07 at 03:24 PM Reply With Quote
loctite then mark bolt head at 12 o'clock with paint and observe before each drive.
if the mark moves, we need to think again.
but then again the tabs and brake pipe braket shouldn't be that diffictul to make up - have you tried biggred if they sell them?
flak monkey
posted on 20/6/07 at 03:32 PM Reply With Quote
They were still available from Ford 18months ago...
Otherwise they need to be lockwired.
Loctite isnt a good idea as it will let go once it gets hot. I would avoid spring washers too...
[Edited on 20/6/07 by flak monkey]
Sera
http://www.motosera.com
panichat
posted on 20/6/07 at 03:46 PM Reply With Quote
I bought some ...
...on ebay a couple of weeks ago.
Not expensive. Would also be easy to make.
Dave
twybrow
posted on 20/6/07 at 03:55 PM Reply With Quote
I too bought some off ebay a few weeks ago. Alternatively someone on here has a template for them. Find it, print it out and cut your own.
Fatgadget
posted on 20/6/07 at 03:57 PM Reply With Quote
Wire lock the bolts with one of these
Mal
posted on 20/6/07 at 05:34 PM Reply With Quote
Nordlock washers
I use Nordlock washers on my discs.
These are pairs of washers. One face has serrations which grip the metal and the
sides of the washer which is in contact with its mating washer have a series of stepped ramps to resist rotation.
See www.engservfast.co.uk
RS components may also sell them.
HTH
Mal
NS Dev
posted on 20/6/07 at 05:52 PM Reply With Quote
I used loctite (green not blue, much stronger stuff and more heat resistant)and a torque wrench, no probs yet (400 miles only though)
SVA man was happy with this and loctite on the caliper bolts too.
chockymonster
posted on 22/6/07 at 12:06 PM Reply With Quote
I've just uncovered a load of schnoor washers, similar to a belleville washer but they have lots of serated grooves to grip against both surfaces.
Those along with the remnants of the tab thingies and some loctite should do the trick. I'm going to mark the surfaces so I can tell if there is any movement.
NS Dev
posted on 22/6/07 at 05:29 PM Reply With Quote
don't bother with the bits of locktab, the shnorr washers are brill, they are much better than anything else but not easy to get hold of!
Thye use them on vibratory road rollers ect to stop em falling apart
chockymonster
posted on 23/6/07 at 09:27 AM Reply With Quote
I walked into my local fastener place and it was the only type of lock washer he had!
Triggsy
posted on 23/6/07 at 04:31 PM Reply With Quote
Westfield do them
Link
