Author: Subject: 12.9 ts steel bar
bobster
posted on 21/6/07 at 09:08 PM Reply With Quote
12.9 ts steel bar
i'm looking for a 400mm piece of steel rod/bar 10mm diameter. needs to be 12.9 tensile strength. (or 4 x 100mm pieces)
flak monkey
posted on 21/6/07 at 09:10 PM Reply With Quote
What are you doing with it?
I assume you are making some suspension pivot bars? You could just use EN16T, or if you want silly strength EN24T, but be warned its a bugger to machine.
Sera
http://www.motosera.com
ed_crouch
posted on 21/6/07 at 10:12 PM Reply With Quote
Ive heard of people using EN8. Im not au fait with EN8, but my guess would be that it machines easier than 16/24...
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
40inches
posted on 22/6/07 at 08:31 AM Reply With Quote
could't you just get cap head allen bolts and cut the heads off? http://www.fastfixdirect.co.uk/code/FilterResults.asp?fType=Fasteners&MainCategoryID=19&ProductCategoryID=418
not that expensive either
