Author: Subject: 4 link boxes again
oadamo
posted on 1/7/07 at 04:02 PM Reply With Quote
4 link boxes again
on my saxo track car ive started to fit the 4 link boxes on the back of the car but does it really matter if the link bars are not
parallel to the road. as i think that when i fit the de dion they might be angled down just a bit to get the right ride height could i get away with it.
adam
[Edited on 1/7/07 by oadamo]
worX
posted on 1/7/07 at 05:10 PM Reply With Quote
How much do you think they will be angled down Adam?
12a RX-7
posted on 1/7/07 at 05:49 PM Reply With Quote
you need to read up about anti squat and anti dive and make up your mind about what you want to run, looks like you have plenty of scope for adjustment so I am sure you will be fine.
posted on 1/7/07 at 06:19 PM Reply With Quote
Parallel to each other is cool as long as they are the same length.
If for any reason you think the geometry is out just use rubber bushes in the upper links --- even hard rubber bushes will let you away with a lot.
oadamo
posted on 1/7/07 at 06:35 PM Reply With Quote
i think about an inch or so because if i move the boxes down any more they wont be level with the bottom of the car.and i was thinking if i hit something it could rip everything off lol. or should i just move them down to suit. and the link bars are about 700mm long as where ive put the boxes was the best place to get a lot of weld on and keep the back end strong but i dont no if there going to be to long .
adam
posted on 1/7/07 at 06:50 PM Reply With Quote
The longer the better with trailing arms is the theory. As long as you have bump and rebound you should be fine with what you describe in my opinion. Are you using a panhard rod with the de dion or another system?
oadamo
posted on 1/7/07 at 06:57 PM Reply With Quote
hi yes iam using a panhard rod.
adam
