ever88
posted on 2/7/07 at 06:11 PM |
13" rims on sierra rear discs
hello all
having difficulty fitting 13" rims to rear sierra disc brakes set up.
I've ground a bit off the caliper but think it may be best to use spacers and extend the wheel studs.
any ideas how others have cleared this problem and are extended wheel studs easy enough to get hold of
grateful of any help
Wadders
posted on 2/7/07 at 06:17 PM |
Hi
Rally design sell longer wheel studs and spacers. depends how much clearance you need to gain.
Al.
Originally posted by ever88
hello all
viatron
posted on 2/7/07 at 06:27 PM |
Just done this on our Avon, we eventually changed to Hi Spec rear calipers, 10mm spacer, longer studs and still had to grind back the ears on the
brake pades!!! Make sure its worth it!!
Also bought some Weller Formula Ford Steel Wheels which helped.
Mac
carlgeldard
posted on 2/7/07 at 06:38 PM |
13" Compomotive CXR Wheels job done!!!!!!!!!
Carl ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
PS Not Locost ![](/images//smilies/shocked.gif) This route will cost £400 at least.
[Edited on 2/7/07 by carlgeldard]
StevieB
posted on 2/7/07 at 07:58 PM |
But you do save on pricey alloy calipers, about £450 for the back in in itself!
bigrich
posted on 2/7/07 at 09:45 PM |
or you can do it the really hard way
![](/galpreviews/a583637-rear wilwoodcxr.jpg) ![Rescued attachment rear wilwoodcxr.jpg](/gallery/a583637-rear wilwoodcxr.jpg) Rescued attachment rear wilwoodcxr.jpg
andyps
posted on 3/7/07 at 08:38 PM |
Bigrich - is that the hard way because of writing all the numbers on the cheque
