Author: Subject: Bottom front A-arm symetrical?
quattromike
posted on 18/7/07 at 06:08 PM Reply With Quote
Hi every one thanks for lookin, I'm getting close to fabricating my front bones, My problem is if I make them parallel to the center of the car the rear leg of the A-arm it going to foul on the chasis. My Idea is if I make the rear leg shorter it'll be ok. But, will this be really bad for the handleing of the car or just bad but not to worrie?
"At the end of the day, I think it's going to get very dark"
blakep82
posted on 18/7/07 at 06:10 PM Reply With Quote
thats how mine are. I'll try and get a photo later...
________________________
Dantheman
posted on 18/7/07 at 06:37 PM Reply With Quote
You'll get some castor angle changes throughout the suspension movement, and probably some slight camber angle changes too. Not disasterous but not ideal.
blakep82
posted on 18/7/07 at 06:43 PM Reply With Quote
^ thats what i thought with mine, but they've been racing pickups for 10years now, and I'm sure SHP used the same design for years before... they do have very little body roll (if any) so maybe thats why it doesn't matter too much. i don't know, but thats how mine are
nitram38
posted on 18/7/07 at 07:00 PM Reply With Quote
If the front is on the left of your diagram, you will get toe-in and out. And because of your steering rack, you will also get bump steer.
The zonda has it's rear suspension on an angle. Perhaps for more grip in corners?
[Edited on 18/7/2007 by nitram38]
Dantheman
posted on 18/7/07 at 07:23 PM Reply With Quote
Some changes in in suspension geometry could be very beneficial but that could only be determined by many hours of testing I guess.
posted on 18/7/07 at 07:47 PM Reply With Quote
Not a good idea it will cause greatly increased bump steer and massive castor changes, and will cause tramlining.
Try this instead
[Edited on 18/7/07 by britishtrident]
[Edited on 19/7/07 by britishtrident]
James
posted on 18/7/07 at 08:11 PM Reply With Quote
Quatromike,
Why is the A-arm going to foul on your chassis when it doesn't on anyone elses?
Some other pretty dramatic changes must have been made!
James
quattromike
posted on 18/7/07 at 09:15 PM Reply With Quote
Yes Mine is very different to normal because I'm not following any plan. I hope this picture helps. The rear of the leg (whice is the one on the right) will be too far in board and will only be about 15mm clear of the chasis so will not be enough for droop in the suspention. and yes it is a curved chasis . Oh and by the way thanks for the info so far.
nitram38
posted on 18/7/07 at 09:26 PM Reply With Quote
Couldn't you bring both points forward?
The only problem then would be good camber gain/loss issues in body roll.
You would need to re adjust all mountings to sort it.
quattromike
posted on 18/7/07 at 10:04 PM Reply With Quote
Yes but it's not very far in board as is so to make the top one shorter would make it way over board which I'm not keen on doing. for chasis strength and looks. What if I made the top and bottom bones with the same alignment to counter act any changes in geometry?
quattromike
posted on 18/7/07 at 10:24 PM Reply With Quote
her's a side view of roughly what it will look like. NTS
quattromike
posted on 2/12/07 at 03:12 PM Reply With Quote
I think I've waste too much time thinking about it and I really should get back into the build so I'll go ahead an make them up and see what happens
Mike
