ever88
posted on 18/7/07 at 09:19 PM |
rear shock dimension details
building a locost chassis and using dion axle.
anyone know the size of rear shock absorbers fully open and closed plus spring rating please.
many thanks to those who input
DavidM
posted on 18/7/07 at 11:11 PM |
It depends where your shock mounts are. Set it all up with the trailing arms parallel to the ground, then measure the distance between the centres of
the mounting holes. Add half your shock travel, say 1.5 inches for open size and minus 1.5 inches for closed size. This assumes nothing else prevents
this much movement of the suspension.
Mine are 180 lb on a live axle but are probably a little hard.
ever88
posted on 19/7/07 at 09:14 AM |
cheers david
will do
