New Topic New Reply
Author: Subject: IRS setup on wide chassis (+442)
ashtal
posted on 29/7/07 at 06:29 PM Reply With Quote
I want to know exactly what im doing when i start welding my 442 chassis together. My doner is a 3.0 v6 vauxhall omega with a lsd. This will be used in my IRS. I have found a bloke who makes a complete irs setup so i only need to make fabricate the chssis to fit.
Has anyone got any pics of an irs setup on a 442 ?
Also what else do i need to add the the 442 as the design does not look like a complete chassis ? Rescued attachment c6c0_1_b.jpg
ecosse
posted on 29/7/07 at 07:29 PM Reply With Quote
Interesting choice of donor, is it the Mv6 version?
Can't help with IRS pics although it has been done b4, try the search and you should find some info, I think there are cad plans floating about for it as well.
You could have a look at the new book for IRS info as well, should be transferrable to the 442 easily enough.
The 442 plans are certainly missing the suspension bracket locations, and I think the transmission tunnel is missing too, but they are easily transferred from the book.
Hope that helps
Alex
ashtal
posted on 29/7/07 at 08:13 PM Reply With Quote
Yeah it is the 3.0 24v mv6, ex police car.
Blakey_boy
posted on 30/7/07 at 09:34 AM Reply With Quote
I hope you've got strong neck muscles!!!
Sounds like what could be a nice set up too. good luck with it
Gene Hunt:- If anything happens to that car, I'm coming round your house and stomping on your toys, Understand?
ashtal
posted on 30/7/07 at 04:19 PM Reply With Quote
LOL, good point. Will have to start working out the old neck muscles !
Matty Dog
posted on 1/8/07 at 04:54 AM Reply With Quote
Mine isn't strictly a Locost or a 442, but here is what I've done to accomodate a '92 Toyota Supra IRS. Still have to fabricate a bottom wishbone as the Supra used a multi-link setup that wasn't really going to work for my application.[img]http://locostbuilders.co.uk/upload/a596926-DSCN3317[1].JPG[/img]
907
posted on 1/8/07 at 06:52 AM Reply With Quote
I just love the chair mate.
It conjures up all sorts of images in my mind.
My chassis was clamped to a bench so I sat on a seed tray.
I admire the "Drawing is only a guide" approach.
Atb
Paul G
ashtal
posted on 1/8/07 at 06:05 PM Reply With Quote
Cheers for the pic mate. That is going to be a wide motor ! Nice
t.j.
posted on 1/8/07 at 08:41 PM Reply With Quote
hey mat,
what is that engine it is not the supra engine is it?
that will be a blast!
[Edited on 1/8/07 by t.j.]
Matty Dog
posted on 7/8/07 at 12:18 AM Reply With Quote
The engine is a 4-litre Lexus V8, attached to a Supra W57 gearbox with a custom bellhousing.
I've got a Triumph Spitfire seat to replace the domestic item!
The motor takes up lots of space. Luckily, I don't want to run power steering, becuase the pump had to come off to fit the motor in! The whole car is a bit bigger than a regular Locost, and I borrowed a few dimensions from the 442 plans. Rescued attachment DSCN3312.JPG
bobster
posted on 7/8/07 at 01:58 PM Reply With Quote
being from an ex police car that engine won't have been over the speed limit will it?
ashtal
posted on 7/8/07 at 04:28 PM Reply With Quote
Not once ! But it will have a superchip, LSD and been strictly maintained
Matty Dog
posted on 5/12/07 at 12:23 AM Reply With Quote
I put the Matterati on its wheels for the first time on Saturday.
Admittedly, there are no front springs or rear coil-overs yet, so it's sitting on blocks, but at least, it looks a little bit like a car.
Matty Dog
posted on 5/12/07 at 12:24 AM Reply With Quote
The rear lower wishbones were a joint effort between some blokes in my club and myself.
I still haven't worked out how I want to mount the rear coil-overs, as this is a pretty high-stress area.
wilkingj
posted on 5/12/07 at 11:07 AM Reply With Quote
Good Pics....
Screams VIENTO to me..
Wonder if any of the Viento body / nose cone will fit. But would be a long way to post it to NZ.
Looks like its going to be fun to drive.
Best Regards
Geoff
http://www.v8viento.co.uk
Matty Dog
posted on 6/12/07 at 02:51 AM Reply With Quote
My car is based on / inspired by / shameless copy of this:
Which is a one-off built in the states in the late 1950's called the "Troy".
wilkingj
posted on 6/12/07 at 08:35 AM Reply With Quote
CHRIST!!!! An oversized Viento
That looks nice.. and the chassis is coming along nicely.
Best of luck with it.
Geoff
Best Regards
Geoff
Schrodinger
posted on 7/12/07 at 07:13 PM Reply With Quote
Rorty's IRS plans might help
http://gtslocost.locostsites.co.uk/
The IRS and De'dion plans are on there
Keith
Aviemore
chrisg
posted on 7/12/07 at 10:19 PM Reply With Quote
Can I ask if you're using the front uprights?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
New Topic New Reply
