New Topic New Reply
Author: Subject: Fuel tank alternative
stats
posted on 2/9/03 at 06:47 PM Reply With Quote
Has anyone used a fuel tank from a donor with any success. I saw a piccie with one from a spitfire and it looks like it could fit. Any comments greatly appreciated
Stats
RoadkillUK
posted on 2/9/03 at 06:49 PM Reply With Quote
I've heard that the spitfire tank fits in nicely (and I'm sure someone has done it). I also bid on one on ebay and lost it
I can't be sure but I think someone has mentioned the use of a Vauxhall Chevette petrol tank as a donor (not sure if it was saloon, hatchback or estate though)
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
chrisg
posted on 2/9/03 at 07:51 PM Reply With Quote
It was Me!!
It's the saloon, don't get the one from the hatch as it's all wrong. The saloon one is between the boot and the back seat so it comes out brand new.
Its big tho 10 gals, and nearly fills the back of my (+4) car.
I can measure it up if any one's interested.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
A Badger
posted on 3/9/03 at 11:11 AM Reply With Quote
Chris,
How is your's mounted? I've got a part built +4" with a tank from a Shuvit. It's mounted vertically with the sender on the side of the tank.
Looks a resonable installtion, though I'm a little worried about getting a fuel guage working with some reasonable accuracy.
Andrew
PS I'm in Sheffield too.
andyps
posted on 3/9/03 at 02:58 PM Reply With Quote
The tank from a mini van / estate / pick up may well fit. On the mini it goes across the back behing the sub frame, under the boot floor with a filler on the off-side. Holds six gallons. It is probably about the right size - I can get approximate dimensions if anyone wants (helped by the fact we have a mini estate!)
I am planning to have a look at this tank with a view to fitting one.
posted on 3/9/03 at 03:55 PM Reply With Quote
theres a 'mini special' fuel tank on ebay at the min for a 5er, if anyones bothered. I though that perhaps it was a bit small. Search for fuel tank, theres not many items...
chrisg
posted on 3/9/03 at 07:10 PM Reply With Quote
Andrew,
mines mounted by the same holes that are used on the Chevette on to brackets across the bottom and by two straps into the holes at the top welded to the back rail.
My digi cams bust but I could mail you a sketch if you like.
Chris
andyps
posted on 3/9/03 at 09:57 PM Reply With Quote
I doubt the mini special tank would be any use - it is probably one from the standard mini which sits inside the rear corner of the boot - the mini van tank is much more the locost shape.
Chris Leonard
posted on 4/9/03 at 11:43 AM Reply With Quote
the spitfire tank fits nicely - paid £10.00 for one
Ian Pearson
posted on 7/9/03 at 06:52 PM Reply With Quote
I've used a Spitfire tank, and it fits like a glove.
Metal Hippy
posted on 7/9/03 at 07:24 PM Reply With Quote
Shouldn't it fit like a fuel tank?
Cock off or cock on. You choose.
kiwirex
posted on 9/9/03 at 08:03 AM Reply With Quote
Read somewhere that someone had used one out of a van.
Can't tell you where, or which van though.
Not much use today...
- Greg H
thekafer
posted on 12/9/03 at 01:05 AM Reply With Quote
sand rail/dunebuggy
Stats
Checkout the spun aluminum tanks that sand rails use.They come in diameters from 6"to10" and lengths from 15" to 36".
I have'nt got that far yet, but I was going to look at these when I did.
Oh, they run $45 to$80 here.
Just a thought Fletch
bob
posted on 12/9/03 at 06:30 AM Reply With Quote
MK 1 Cavalier
For the bigger tank,probably the same as the Vauxhaul chuvette.
Ian Pearson
posted on 12/9/03 at 09:03 AM Reply With Quote
Can't remember the exact capacity, but it's a tad under ten gals. Can send you a couple of pics if you want?
New Topic New Reply
