Author: Subject: Slackness in rear panel
andyd
posted on 3/9/03 at 12:00 PM Reply With Quote
Has anyone got any suggestions about how to tighten up an aluminium rear panel once it's been "dressed" (and I use the word in loose terms)?
Our rear panel has not wrapped tightly around the top tube in a couple of places. I think it was because we cut off too much metal before hammering it over the top and as such not enough pull was exerted on the panel as a whole.
Would heating it up somehow allow us to make it tighter?
mreveready
posted on 6/9/03 at 03:47 PM Reply With Quote
Only a suggestion!
Every panel except ones I require for access have been bonded with a very high strength adhesive sealer (31kg per square cm strength)
This also strengthens the entire chassis.
Given the ideal distance between mating surfaces is 3.2 mm, it would certainly take up the slack and tighten the chassis and panels.
Hope this helps.
The pleasure has been all mine.
http://www.mreveready.com Online at last.
Stu16v
posted on 6/9/03 at 08:37 PM Reply With Quote
You wouldnt know where to get some by any chance?
mreveready
posted on 6/9/03 at 11:45 PM Reply With Quote
mailed you with details.....
mreveready
posted on 7/9/03 at 09:58 AM Reply With Quote
Stu,
Please mail me and I'll send details, I posted mailed you prior to seeing you don't have your e-mail address listed.
Mark Allanson
posted on 7/9/03 at 11:42 AM Reply With Quote
If you are going to paint the back panels, you could use a shrinking dolly and hammer, DA off the dimples and stopper the pits and nobody would know - except us!
Stu16v
posted on 7/9/03 at 08:09 PM Reply With Quote
Sorry mate, just pulling your leg....(broused your web site....)
andyd
posted on 8/9/03 at 08:21 PM Reply With Quote
Well we've decided to start again because we're not happy with the outcome. It may interest someone at least to know that we'd used 16SWG ally and not 18 as Mr Ron suggested. We will be buying a sheet of 18 and making the bonnet soon so we'll see if that thickness can be "dressed" more succesfully before buying yet another sheet to redo the back panel.
Oh isn't this learning by trial and error fun! Expensive too!
