Author: Subject: Looking for safety valve design
posted on 7/8/07 at 06:54 PM Reply With Quote
This is one for the model engineers on the forum (I think there are a few)...
I want to put better safety valves on my steam loco, as the ones I've got don't re-seat very well - they keep fizzing and bubbling once the pressure's gone down below the operating pressure.
Does anyone have a decent design for a 'pop' or 'semi-pop' safety valve? Or a pointer to one? It would have to fit a 1/2" x 26tpi mounting boss, and be an inch or more in height (but that dimension's not a major issue).
I've had a look through many model engineering mags, but the only interesting designs seem to use commercial springs (min. order £25 + VAT!).
cheers,
rusty
posted on 7/8/07 at 07:52 PM Reply With Quote
What is the blow off pressure
posted on 7/8/07 at 09:08 PM Reply With Quote
80 psi.
caber
posted on 7/8/07 at 10:03 PM Reply With Quote
What sort of loco is it? It should be easy enough to make a pair of salter spring balance type with a nice machined and ground in cone that will seat well. may not suit all designs of loco!
Caber
posted on 8/8/07 at 07:23 AM Reply With Quote
It's this thing...
The design is called a "Sweet Pea", hence it's called "Lathyrus" (we've had that discussion elsewhere!). 5-inch gauge.
I know the type of safety you're talking about - I have considered it, and it would be in keeping with the general design. Not sure what the club's boiler inspector would think of them though...
cheers,
posted on 8/8/07 at 08:23 AM Reply With Quote
Safety valves often need a clout to reseat them when they lift --- but they shouldn't need lift in any other situation than when demonstrating to the surveyor that they lift. At SWP they shouldn't be any where near lifting.
posted on 8/8/07 at 08:30 AM Reply With Quote
Clouting the tops of the safety valves is NOT a good way to operate! Saying that, I'm having to gently tap the valves to stop them fizzing, which is a pain as they normally have 'chimneys' fitted on top.
That's why I want to make 'Ross pop' or 'semi-pop' valves - they do shut firmly, hence the name 'pop', which is the sound they make when they shut. The only disadvantage of the full 'pop' valves is the sudden and very load roar they make when they open, which invariably makes the user jump six foot in the air! The 'semi-pop' ones give a bit of a warning before they lift...
posted on 8/8/07 at 08:35 AM Reply With Quote
Just for a laugh, here's an old picture that shows my 'invisible man' impersonation!
Metal Hippy
posted on 8/8/07 at 06:15 PM Reply With Quote
He emerges out of the shadows to pass comment to an old mate..
Better we see steam than your face matey..
How the bloody hell are we?
Cock off or cock on. You choose.
posted on 8/8/07 at 06:38 PM Reply With Quote
Me? I'm bleedin' marvellous!
How's you?
(and I can understand the wish to avoid seeing my face... )
Metal Hippy
posted on 8/8/07 at 06:44 PM Reply With Quote
Ahhh you know..
Life ticks on.
