Author: Subject: Air compressors
Johneturbo
posted on 8/8/07 at 04:33 PM Reply With Quote
Air compressors
Hi all
been looking at some air compressors on ebay
i'm after one that will have enaugh oomph
to undo hub nuts.
seen this one on ebay
http://cgi.ebay.co.uk/AIR-COMPRESSOR-3hp-100lt-motor-230v-BRAND-NEW-ZJ30100_W0QQitemZ170137604818QQihZ007QQcategoryZ30906QQssPageNameZWDVWQQrdZ1QQcmdZ ViewItem
not so sure on the make, on no warrenty
also
this sealey one
http://cgi.ebay.co.uk/Sealey-SA22503-Direct-Drive-3HP-Air-Compressor-50-litre_W0QQitemZ130139705591QQihZ003QQcategoryZ30906QQssPageNameZWDVWQQrdZ1QQcm dZViewItem
what ya think?
ps dont have much more than £150 to spend.
john
[Edited on 8/8/07 by Johneturbo]
caber
posted on 8/8/07 at 04:54 PM Reply With Quote
Sealy one should be OK but don't bother with the coily hose. It won't flow enough air, go and get a 10mm rubber hose. You are also best to get a load of quick connects, this sort of stuff soon blows your budget!
Caber
big_wasa
posted on 8/8/07 at 05:14 PM Reply With Quote
Yeh the sealey one would be fine for that but would struggle with some sparay guns and things like Media blasting cabinets.
tks
posted on 8/8/07 at 05:16 PM Reply With Quote
buy 1 sell it on, buy another sell it on again.
Then your budget is 200 buy a last one and hose and the necc assoires
Tks
Johneturbo
posted on 8/8/07 at 05:21 PM Reply With Quote
Good point Caber about the coily hose, i think i'll go for the sealey one as its a know brand.
Big_wasa,mainly want it for rattle gun,drill and sanding tools.
and to pump me tyres up
cheers guys
Johneturbo
posted on 8/8/07 at 05:29 PM Reply With Quote
Tks
If i was to do that i'd make a loss
bobster
posted on 8/8/07 at 05:39 PM Reply With Quote
i have bought the 3hp sealey unit from fleabay. has been excellent. no problems spraying whatsoever. would recommend
posted on 8/8/07 at 06:58 PM Reply With Quote
Get an electric drill and sander, you'll use less electricity and make less noise. You tools won't freeze up in winter either I have a 3hp v twin and spray using a gravity feed gun quite effectively but I only use it for that and blowing tyres up nowadays.
[Edited on 8/8/07 by Peteff]
mark chandler
posted on 8/8/07 at 07:44 PM Reply With Quote
I,ve got one like the top one, was nearer £99 from memory.
Its okay.... nothing special but will run airguns okay and keeps up with spaying just.
Not any good for blasting.
If I was to spend again I would look for a big one second hand off ebay.
Regards Mark
