New Topic New Reply
Author: Subject: MK Silencer Problem
John22000
posted on 9/8/07 at 06:33 PM Reply With Quote
MK Silencer Problem
Hi All,
Has anybody out there ever taken the end off the standard Indy Pinto exhaust can.....?
The 4 Rivets holding the tailpipe to the can on mine are rattling like hell...
Is taking the end off a good idea or not ?
I guess when I drill out the old rivets I'm going to push part of them inside the can and would like to remove these.
Will I be able to retrieve the bits if I take the tailpipe off completely.
More to the point will I ever get it back on again...???
When (If) it goes back together I think I'll add another 4 equally spaced rivets as well just for good measure.
All thoughts gratefully recieved.
John
cryoman1965
posted on 9/8/07 at 07:55 PM Reply With Quote
Yes you can take it apart. Drill out with probably a 5mm bit.
The end section will pull out but a bit of force maybe required.
Refit with a rubber mallet if force is required.
You will be able to remove the old rivets from inside the can.
Put a line of exhaust sealant around the can and in the rivet holes to seal.
The new rivets should not rattle.
HTH
Nige
[Edited on 9/8/07 by cryoman1965]
John22000
posted on 10/8/07 at 12:28 PM Reply With Quote
Thanks Nige,
I'll give it a go tonight, the stainless rivets have just been delivered.....
John.
New Topic New Reply
