Poll: What do you think my car will weigh when finished? [View Results]
Less than 400kgs
400 - 420kgs
421 - 440kgs
441 - 460kgs
461 - 480kgs
481 - 500kgs
More than 500kgs
<<  1    2  >>
Author: Subject: What do you think my car will weigh when finished?
TimC
posted on 20/8/07 at 08:24 AM Reply With Quote
I'm just wondering what my car will likely weigh when completed. What do you think? Weight impacting specs as follows.
MNR Vortx RT+ with 2001 R1 Engine on Carbs.
Asymetric Roll-bar with diagonal to footwell.
No reverse mechanism.
Small Fuel Tank.
13" minilite-style wheels.
Custom loom - no lights aside from high-level brake light.
Fibreglass seats (one trimmed.)
Viscous Sierra Diff with Lobro shafts. Standard Cortina Uprights with M16 calipers. Fiesta Calipers at rear.
speedyxjs
posted on 20/8/07 at 08:37 AM Reply With Quote
Im guessing 400-420
What do we win if we are right?
procomp
Hi Tim At the moment its 100% 400-420 only me voted so far though
But will move up when reverse is fitted assuming you are going to get a licence.
I know the St locosts with blade came in at 440ish before attacking with the wallet and alloy parts.
So now the challenge is to get it below 400. But remember the lighter you go the more attention needs to be paid to the spec of the dampers.
cheers matt
Yes indeed what do we win if correct. Is it a brand new fully built gulf coloured MNR rt + with r1 engine.
[Edited on 20/8/07 by procomp]
welderman
posted on 20/8/07 at 08:41 AM Reply With Quote
441 - 460kgs 2 (50%)
Thank's, Joe
I don't stalk people
worX
posted on 20/8/07 at 08:53 AM Reply With Quote
441 - 460kgs from me too mate!
Are you talking about a genuine wet weight by the way?
Steve (with a car that weighs 451Kgs with 7 litres of fuel )
smart51
Do you have padded seats? Boot box? Interior trim? Carbon or GRP?
How heavy are your alloys?
Have you cut all your bolts to length?
Its hard to estimate without all the details.
TimC
posted on 20/8/07 at 08:59 AM Reply With Quote
Okay, fair point - person who is the closest (Vote and then state in numbers in the thread) will win a £5 ebay voucher.
Weights will be from set-up session at Procomp so perhaps Matt should be banned from entering for fear that he rigs the scales!
TimC
posted on 20/8/07 at 09:03 AM Reply With Quote
Not sure on the weight of a wheel. Will check. One seat is lightly padded but there's still not a lot of weight to it. No boot box. No interior side panels - just the tunnel cover. All panels are GRP. All bolts thus far are minimum length but the suspension ones will be used as supplied at least to start with.
TimC
posted on 20/8/07 at 09:05 AM Reply With Quote
Originally posted by worX
Are you talking about a genuine wet weight by the way?)
Yep, no funny business. Wet weight.
worX
posted on 20/8/07 at 09:37 AM Reply With Quote
I want to change my guess! I forgot you aren't putting any lighting on it are you?
What wheels are you using?
I will guess at 535Kgs!!!
TimC
posted on 20/8/07 at 09:44 AM Reply With Quote
If it weighs 535kgs I'll be setting light to it!
Agriv8
posted on 20/8/07 at 10:02 AM Reply With Quote
400 TO 420.
Actual weight to be 418k.
Regards
Agriv8
Big Daz
posted on 20/8/07 at 10:11 AM Reply With Quote
Going on the weight of our Avon (approx 536 Kg)
and a similar build except CEC & bigger tank
I go for 481 -500 Kg
I will opt for 485 Kg Wet weight
Daz
smart51
posted on 20/8/07 at 10:19 AM Reply With Quote
I will guess at 535Kgs!!!Steve
Thats what my RT weighed with a huge bag of tools in the boot, with lardy wheels, sierra uprights and vented discs plus comfy seats, lights, trim panels and all fluids to maximum.
Mind you, the savings might only add up to about 50 kg so I'm guessing at 485 kg
[Edited on 20-8-2007 by smart51]
speedyxjs
posted on 20/8/07 at 10:28 AM Reply With Quote
I recon 419Kg's
alanr
posted on 20/8/07 at 10:45 AM Reply With Quote
It will be just a smidge under 500kg - say 495kg
That is what mine weighs with an empty boot and a gallon of fuel
Avoneer
posted on 20/8/07 at 11:05 AM Reply With Quote
465kg.
Pat...
worX
posted on 20/8/07 at 11:07 AM Reply With Quote
HAHAHAHAHAHAHAHAHAHA
I actually meant to put 435Kgs!!!
But now I'm not sure, 'cos when you say you will set fire to it - I should be worried even more about the weight of it, since YOU HAVVE ALREADY SET FIRE TO IT!!!!!!!!!!!!!!!!!!!!!!
[Edited on 20/8/07 by worX]
amalyos
posted on 20/8/07 at 11:42 AM Reply With Quote
My RT+ with an R1 Engine and 3/4 of a tank weighs 515KG (without my 95KG)
15" wheels
Intertrim seats (padded fibreglass)
Cortina Uprights, Calipers & Vented disks.
Ally front hubs.
7.5" LSD (since changed to 7" open)
No Reverse
To get your car down to the low 400s, your going to need light weight panels, as they are a big contributor.
http://stevembuild.blogspot.com
twybrow
posted on 20/8/07 at 11:51 AM Reply With Quote
I think 438kg wet (without driver).
procomp
posted on 20/8/07 at 01:35 PM Reply With Quote
Hi OHh. no problem. And i will not reveal your weight either when done.
cheers matt
GeorgeM
posted on 20/8/07 at 08:48 PM Reply With Quote
no reason, -just a guess, 462Kg
progers
posted on 22/8/07 at 08:15 AM Reply With Quote
475Kgs is my vote!
I know someone who had an MNR with Blade engine and it weighed in at just under 500Kgs wet with cage. The MNR seems to be a heavier than average chassis (no bad thing for safety) and the bodywork is also substantial. You will need to add quite a few lightweight bits (hubs, wheels, brakes etc) and go minimalist on fixtures to get below 460kgs I would imagine.
- Paul
road warrior
posted on 22/8/07 at 01:21 PM Reply With Quote
455kg with 10 litres of fuel
iank
posted on 22/8/07 at 01:34 PM Reply With Quote
Don't often see such nice Gaussian bell curves on the opinions in the polls.
I'd say the Locostbuilders borg mind is suggesting 450kg ish
Anonymous
<<  1    2  >>
