Author: Subject: help please on chassis no
perky 91
posted on 29/8/07 at 06:26 PM Reply With Quote
once again im after some help
have sent all paperwork of to sva car yesterday only to recieve a phone call today yes today saying i have used wrong chassis no,, i had used chassis no from donor vehicle, could someone please tell me what or where i get a chassis number from
many thanks
Davg
posted on 29/8/07 at 06:35 PM Reply With Quote
Hi , write or take a letter to local DVLA tell em you are building a kit car & proposing you chassis no & ask if O.K. with them. Seems some say ok other will allocate a chassis number for you to stamp.
cheers D
russbost
posted on 29/8/07 at 06:42 PM Reply With Quote
If you make up a 17 digit no. composed of no.s & letters which is unlikely to be duplicated this should be satisfactory to them
perky 91
posted on 29/8/07 at 07:07 PM Reply With Quote
great thanks
do i simply stamp up a piece of alley and rivet it to car as a plate (once approved)
thanks again
Davg
posted on 29/8/07 at 07:12 PM Reply With Quote
Needs to be permanent on chassis at front end drivers side normally in addition to a stamped plate. Keep it tidy though & minimum size for teaps cant remeber the size at the mo. someone will confirm. as you say once approved!
Macbeast
posted on 29/8/07 at 09:06 PM Reply With Quote
When inventing a chassis number, certain characters should not be used - I think "I" (as in India) "O" as on ostrich. But do a searcch- this was covered quite recently
NeilP
posted on 29/8/07 at 09:33 PM Reply With Quote
Minimum 5mm letter height and no 'I' or 'O' (substitute 1 and 0 [zero]) as stated
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 30/8/07 at 08:29 AM Reply With Quote
yes it has so I won't bother retyping.
I made a plate and riveted to scuttle; other one was stamped on to a cleaned up area of chassis then varnished over to stop it rusing.
DarrenW
posted on 31/8/07 at 10:54 AM Reply With Quote
I stamped a plate and welded to chassis. DVLA dont like rivet on (or at least Stockton dont). I also engraved the number to an easier to access rivetted on plate so SVA man didnt have to go looking.
After SVA and registration i also put the chassis number on loads of components and other areas of chassis inc loads of hidden places.
