RichardK
posted on 4/9/07 at 09:18 PM |
Running without the alternator wired up
Got most of the plumbing done and would like to have a try at setting up my carb, but seem to remember somewhere saying thats it a no no to run the
alt without it being connected, so I thought I could wire it up temporily if I was told what goes where, standard sierra alt or just get one of those
emergency fan belts and cut it down so it misses the alt but still drives the water pump.
Is it still a no no?
Any other suggestions so I can run my engine for a bit longer, also heard soething about running in a new cam at 2k revs for 20 mins, so defo need the
coolent in.
I'll just wait then for my core plugs to fall out cos I didn't know they needed to be glued in But they might be ok
As always comments welcome.
Rich
Gallery updated 11/01/2011
owelly
posted on 4/9/07 at 09:40 PM |
Running without the alternator wired up will be fine. If there is no juice getting to the excitation, then your alternator is just a bundle of
spinning bits and cannot hurt anything! But your engine will run out of sparks when the battery is flat!!
daviep
posted on 4/9/07 at 09:49 PM |
If it is a Lucas alternator with a plug which looks like this
![](/galpreviews/8images.jpg) ![Lucas plud](/gallery/8images.jpg) Lucas plud
Then it's pretty simple. The small terminal (IND) should be connected to battery positive through a bulb.
Either of the big terminals should be connected to battery +ve using a reasonably heavy piece of cable.
The Alternator body must be connected to earth.
To test your wiring: remove the small wire (IND) and touch it to the alternator casing. The bulb should light, this proves your warning lamp is wired
correctly and that the alternator is earthed.
Remember to disconnect the wiring or the battery when you are finished as the circuit is not switched or fused.
Regards
Davie
DarrenW
posted on 4/9/07 at 10:33 PM |
Core plugs - i thought if fit tolerance is OK then no sealant required. Most people recommend sealant when retro fitting later etc As you say you may
not need. You havent lived until youve had one fail![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Ref alternator - id wait until wired up etc correctly. Nowt like knowing all is well for piece of mind.
posted on 5/9/07 at 07:34 AM |
Never run without the alternator properly wired up.
Contrary to what has already been posted there can be enough residual magnetism in the stator to provide excitation.
posted on 5/9/07 at 08:41 AM |
see my post yesterday about this.
according to green bible either run fully wired or fully disconnected. (I did wonder about the residual magnetism bit)
craig1410
posted on 5/9/07 at 12:26 PM |
I've never had a problem running with the Alternator completely disconnected - I think it i s very unlikely to cause any damage.
When you do wire it up, make sure that the wire between the large terminals and the battery are rated higher than the maximum output of the
alternator. I used two seperate wires of 30A each from Alternator (45A max) to battery rather than one large wire. I connected one spade terminal to
each of the large connectors and then ran this to a single bolt-through terminal on the starter solenoid. Easy.
Craig.
posted on 5/9/07 at 01:26 PM |
I used the original 2 wires as they are easier to bend than a thick single wire and as said if completely disconnected it should be no problem.
robbydee
posted on 18/11/07 at 06:40 PM |
Regards
Davie
Sould i run a seperate wire from the alternator mounting bolts to the chasis?
Macbeast
posted on 18/11/07 at 08:06 PM |
Normally alternator body is bolted to the engine block and thus earthed through it. Engine block should then have a heavy braided cable to chassis and
thence to battery negative.
To be 100% sure run braided cable from battery negative to engine block preferably at the starter mounting bolt.
