Shamrock GS
posted on 6/9/07 at 11:32 PM |
Ignition warning light - wont go off
I hjave wired up a Vicky Green loom and everything works (finally) except that the ignition warning light doesn't go off when the engine starts
- any ideas?
Gary
Sun Tzu, The Art of War
NeilP
posted on 6/9/07 at 11:47 PM |
Alternator no worky or you've plumbed up the wrong connector to the back of it - You're looking for 0v when off and 12v when running...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
daviep
posted on 7/9/07 at 12:54 AM |
Have a lookHERE to see how to test the wiring, was discussed only 2 days ago.
Even if it is not a lucas alternator the wiring will be similar and will work the same. Small wire will be ign. lamp, heavier will be positive to the
battery.
omega 24 v6
posted on 7/9/07 at 08:45 AM |
remove the small thin wire from the alternator and tie it away from the chassis. Turn on the ignition and the warning light should NOT illuminate.
Touch the removed wire to the chassis and the light should illuminate. If this is ok the suspect your alternator is goosed or your on the wrong
terminal. If the light comes on when the wire is removed and not touched to the chassis then you've got a wiring problem.
[Edited on 7/9/07 by omega 24 v6]
posted on 7/9/07 at 09:01 AM |
igntion 12 V ----- lamp ------- alternator charge connector
^^^ that is how it should be wired
depending on your alternaotr, if it is lucas with 3 tabs, the smallest tab is for the charge lamp.
other types have studs, and the one labelled D+ is the charge lamp.
grusks2
posted on 8/9/07 at 08:58 PM |
My light wont go out on tick over - once i bring my revs up it goes out and stays out.
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
omega 24 v6
posted on 8/9/07 at 09:53 PM |
Just as it should do. It's working fine. You'll also find that as soon as the light goes out the voltage at the battery jumps from
11.something to 13.something.
scudderfish
posted on 10/9/07 at 12:42 PM |
My V8 Fury was exactly the same. I thought I had a knackered alternator until I gave it a bootful testing that I'd wired the adjustable rev
limiter in correctly. It goes out at about 2.5k rpm and then stays out when it goes back to idle. Mash the loud pedal and see what happens
posted on 10/9/07 at 01:54 PM |
Shouldn't do that fault you have somewhere --- Assuming the fanbelt is tight if the alternator has spade connections start by checking those
they carry a lot of current.
robbydee
posted on 18/11/07 at 06:32 PM |
what about if the light glows dimly while driving.. at various different times its brighter than others..
Macbeast
posted on 18/11/07 at 08:09 PM |
Slipping fan belt.
[Edited on 18/11/07 by Macbeast]
robbydee
posted on 18/11/07 at 09:03 PM |
deffinatly not the fan belt..
Macbeast
posted on 19/11/07 at 08:09 AM |
Just remembered - I had something similar on my Rascal van. Cleaned up connectors at lack of alternator and it went away. But I'm sure you would
have tried that.
The light goes out when the alternator output voltage approaches or equals the battery voltage so presumably this is not happening - it's either
higher or lower than the battery voltage. you could measure battery terminal voltage, alternator output voltage and voltage on the IND terminal
(connection to the charge light) This should give you an idea of what's going on.
I would suspect poor connection between alternator and battery, battery itself and then alternator regulator
(in order of expense )
robbydee
posted on 19/11/07 at 12:16 PM |
have replaced the multiplug on the alternator and replaced the regulator inside it..
