Dutchman
posted on 10/9/07 at 10:30 PM |
Diff problem
I'm using Lada diff it has 4.3 ratio and the gear box is
1st 3.75
2nd 2.30
3rd 1.49
4th 1
and motor is from fiat coupe 2.0L 16v 155bhp
when i start it full throttle it slip till the mid 3rd gear ... on 17inch 225/45 PZero tires ...
some ideas how to make LSD or some other advice ...
thx
Tarzan English with foreign accent!
Avoneer
posted on 10/9/07 at 10:37 PM |
Learn to drift?
Sorry, don't really have a good answer.
Pat...
blakep82
posted on 10/9/07 at 10:50 PM |
don't know if an LSD would really help. I've got one on my tin top, and i'd rather do without sometimes. when it rains all it does
is make both back wheels spin and there's no grip at all. any different axles available to you? did Lada have any different axle ratios?
edit: or don't pull away with full throttle?
[Edited on 10/9/07 by blakep82]
________________________
Dutchman
posted on 10/9/07 at 11:15 PM |
there is 3.9 diff from Niva but I don;t know will it help
CGILL
posted on 11/9/07 at 07:11 AM |
Angle top links to use torque reaction to push axle down.
You can use an esky diff with the lada axles and housing for more ratios, will require a 3mm spacer made up for between the housing and head.
Have the spider gears shimmed up to load the side gears more, creates resistance for the spider gears to turn, el-cheapo LSD but works well on such a
light car.
Avoneer
posted on 11/9/07 at 11:10 AM |
The 3.9 will definfately help a lot.
Pat...
Dutchman
posted on 11/9/07 at 11:53 PM |
found a guy who maybe can make LSD from regular diff , will see him during the week I hope ...
