Author: Subject: daft question
Mark.
posted on 25/9/07 at 09:08 PM Reply With Quote
daft question
If someone was to remove the windscreen and wipers from their landcruiser would they be able to submit it for an mot?.
Mark
bigrich
posted on 25/9/07 at 09:14 PM Reply With Quote
yes but would be worth disconnecting the washer pump to avoid the squirt in the eye senario i take it you have a large crack/damaged area on the screen?
If it aint there it can't be tested
NeilP
posted on 25/9/07 at 09:15 PM Reply With Quote
IIRC there is something about the vehicle being presented in the condition (state) as provided by the manufacturer - i.e. If built to have a windscreen then should have one fitted.
I know that many (older) vehicle have fold down screens but again, as manufacturer intended?...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
robinbastd
posted on 25/9/07 at 09:18 PM Reply With Quote
Mark - You know the answer - take it to ######## ###### in ##########
Ian
http://smuttygifts.com/
Fozzie
posted on 25/9/07 at 09:19 PM Reply With Quote
ooOOoo ...well... it really is down to the MOT tester as to how strictly he sticks to the rules...
The 'stickler' is within his rights to say, that it (land cruiser) left the factory with one, so therefore it should have one now......
Fozzie
russbost
posted on 25/9/07 at 09:29 PM Reply With Quote
Rubbish - vehicle is tested as presented, if it's got no screen it needs no wipers & washers. What the insurance co. would have to say if you were driving without a screen & had a bump is another matter of course.
blakep82
posted on 25/9/07 at 09:34 PM Reply With Quote
once took a honda for MOT knowing fine well the wipers didn't work right (the switch was broken and you have to hold the switch up to make them park properly, so had a bit of string tied to the heater controls to hold it up)
took it for MOT, it failed. the switch happened to be the same as a rover one, but fitted on the opposite side of the steering wheel so all the pictures would have been upside down.
went to a breakers to try and swap it, but it didn't work right. think the pulg was wired differently too.
expalined to the tester i'd looked for one everywhere, but without luck.
"nothing in the rules to say a piece of string can't be used to make it work..." he said.
"besides, it's fine now and will break tomorrow" i said.
tester let it go.
moral of the story... well there isn't one, but its up to the tester
________________________
Mark.
posted on 25/9/07 at 09:47 PM Reply With Quote
Not my truck but a lad i work with who managed to bust the screen when he took it out to repair the scuttle area...numpty hoofed tad too hard and cracked the screen
Mr R, would that be the wee place that mot'd the toyota street racer even with a cracked headlight?
Mark
Scoob
posted on 26/9/07 at 07:06 AM Reply With Quote
AFAIK as long as you say that its used for dry days only (I.e when they wont need to be used) you can get away with it.. Its all new laws that came in about a month ago, i had to learn them for when i working in a garage
i THINK its the same for headlights etc, you can its for day use only, and they have to take your word for it.. So it should be ok if you state it wont be used in the rain etc..
DarrenW
posted on 26/9/07 at 09:13 AM Reply With Quote
So how does the construction and use regs / law fit into this Q then? Is that seperate to MOT?
I know the thread is only concerning the MOT itself but what would happen if said vehicle was in every day use (with MOT, insurance, tax etc).
MikeR
posted on 26/9/07 at 09:40 AM Reply With Quote
What would happen if you 'failed' due to say a headlight, told them its "day use only" and got the MOT. You then fixed the headlight and wanted to use the car at night - would you need a new MOT?
posted on 26/9/07 at 09:46 AM Reply With Quote
In the case of most lights, if fitted they have to work.
blakep82
posted on 26/9/07 at 10:10 AM Reply With Quote
^ so just whip them out then? if they're not there thy can't be tested?
similar to bike tests then i suppose
