Author: Subject: SVAing a turbo'd BEC?
CraigJ
posted on 27/9/07 at 03:07 PM Reply With Quote
Has anyone done it? wonering if it will be possible?
Guinness
posted on 27/9/07 at 03:12 PM Reply With Quote
Jambojeef has just passed the SVA at Newcastle with a home brewed turbo kit, on a CBR1000 on carbs.
HTH
Mike
matt_claydon
posted on 27/9/07 at 03:17 PM Reply With Quote
Don't see it would make any difference. Emissions test is done at lowish RPM with no load - turbo shouldn't really come into effect.
jambojeef
posted on 27/9/07 at 03:19 PM Reply With Quote
Indeed I have!
Cheers Mike - sorry to have missed the Church Mouse last night btw (again) - next month.....!
If you're thinking of emissions - my engine was a 1991 so the pre-cat test and it sailed through....... when I got my ignition leads made up properly.
I reckon you could always leave a hose off and pass with a turbo fitted but not boosting. Im sure theres a way!
Geoff
CraigJ
posted on 27/9/07 at 03:29 PM Reply With Quote
Sounds good for me then, think i'll go ahead with it then.
Cheers guys.
Paul TigerB6
posted on 27/9/07 at 03:57 PM Reply With Quote
Just thinking aloud - if using a later engine with a cat fitted into the exhaust system, would having a turbo not aid the emmisions test by allowing you to producing more heat in the exhaust system (so the cat will work properly)??
macdave69
posted on 28/9/07 at 06:15 PM Reply With Quote
Originally posted by jambojeef
Indeed I have!
Geoff
In what way did the ignition leads fail the SVa and what did you do to correct it? Only asking as I have my SVA coming soon
