Author: Subject: White smoke from a turbo deisel
sonic
posted on 13/10/07 at 09:50 PM Reply With Quote
Hello all
Do any of you guy's know what this problem could be?
My father has a Kia Sedona people carrier automatic 2.9 turbo deisel.
He is driving along all is fine and then he accelerates to overtake and there is a loss in power and clouds of white smoke coming out of the exhaust.
Pulls over and stops engine starts ticks over ok sounds as normal and shows no signs of fluid loss either water or oil and no cross contamination between the two.
It has lost power and smokes and thats it.
Green flag came and took it to the local garage for them to give there opinion on Monday.
I have my own opinion that the turbo is dead and is passing oil over the seals.
Any ideas would be great
mookaloid
posted on 13/10/07 at 10:01 PM Reply With Quote
Sounds about right to me mate
sonic
posted on 13/10/07 at 10:07 PM Reply With Quote
Hi Mark
How you doing
Not had chance to see you up at Harewood this year.
Are your times still going in the right direction!
Mick
COREdevelopments
also agree, check the turbine on the intake side to see if its collapsed.
bigrich
posted on 13/10/07 at 10:17 PM Reply With Quote
i would check the intercooler pipes aswell just incase one is split or has fell off
sonic
posted on 13/10/07 at 11:14 PM Reply With Quote
Assuming it is the turbo
Anybody know the best place to buy a reconditioned one ?
NigeEss
posted on 13/10/07 at 11:17 PM Reply With Quote
White smoke and no coolant loss, probably running seriously rich and the white smoke
is unburnt diesel.
How's the fuel consumption ?
sonic
posted on 13/10/07 at 11:36 PM Reply With Quote
Hi there
The fuel consumption prior to this happening was 30 -35 mpg which was very good he doesnt drive very fast!!
marcotuinenburg
posted on 14/10/07 at 05:55 AM Reply With Quote
That will be one verry expensive trip to your garage i think.
Good luck with it.
I Also think it is the turbo.
posted on 14/10/07 at 03:17 PM Reply With Quote
An injector is a likely the turbo --- easier to check the turbo first.
