New Topic New Reply
Author: Subject: any experience with et19 wheels on sierra uprights
rotax78
posted on 19/10/07 at 05:28 PM Reply With Quote
Has anybody had any experience with fitting et19 offset wheels on to sierra uprights? I am able to get 13" slicks for beer money so what about fitting them to the readily (read cheaply) available 13" et19 rs type alloys. I know the sierra uses et38 so what are the handling implications. I have willwoods fitted, so clearance with the 13" shouldn't be an issue. Many thanks Simon
higgsti
posted on 19/10/07 at 05:57 PM Reply With Quote
ive got a set of rs alloys in that size your welcome to bring your car down and try on before you commit to buying some im in bolton
rotax78
posted on 19/10/07 at 06:07 PM Reply With Quote
cheers for the offer but at the moment i'm really just after anybodys opinion on how they effected the handling of the car with regards to the offset, thanks again for the offer.
higgsti
posted on 19/10/07 at 06:17 PM Reply With Quote
most 13" wheels are et 19-24 mine are on a westfield car handles well but may be different to you indy? especially with seirra uprights.im looking for slicks myself were are you buying from
[Edited on 19/10/07 by higgsti]
rotax78
posted on 19/10/07 at 07:44 PM Reply With Quote
slicks are from a friend of a friend :-)
bimbleuk
posted on 20/10/07 at 07:15 AM Reply With Quote
Strikers use 18-22ET and they are well known for good handling.
GeoffB
posted on 20/10/07 at 04:30 PM Reply With Quote
i use rs alloys with 19 et..i run Ao48r and found them to be execellent 185/60/13
in the front i use standard sierra vented discs and claipers..i did have to just touch a file to a small aera of the calipers then they fitted fine
on the back i run normal drum brakes and have no problem
i also had to modify the front cycle wings to cover better..
i have done a couple of trackdays with this size and find it turns in tighter and seems to stay tighter through the corners
hope this helps
kastrato
posted on 20/10/07 at 04:56 PM Reply With Quote
I am about to do the same I bought some rs wheels of ebay and a set of michelin slicks from sticky-slicks
I have not put them on the car though cause the car is in Greece and I want go there until summer!
So finger crossed they will fit.
If somebody have few pics of this set up please post them in order to see how they look and what sort of modification the sierra disks and calipers need.
MK INDY fireblade
New Topic New Reply
