Author: Subject: Cam operated fuel pump replacement?
MattCraneCustoms
posted on 25/10/07 at 05:21 PM Reply With Quote
I have a peugeot 1.4 XS engine which uses a cam-operated fuel pump, is this a diaphragm type? I'm just wondering whether this could be removed, the hole covered, and then an electric fuel pump used instead. finding new gaskets and parts is a little tricky for it, and I'd have thought an electric pump would have been better anyway. Any thoughts or experience with this?
Thanks,
Matt
blakep82
posted on 25/10/07 at 05:35 PM Reply With Quote
an common mod on the old mini...
don't know how you'd do it on a peugeot
________________________
stevec
posted on 25/10/07 at 05:50 PM Reply With Quote
On a Peugeot, just fill the hole with Garlic.
Steve.
posted on 25/10/07 at 05:53 PM Reply With Quote
Old minis had electric pumps, later A+ had mechanical If you have a return pipe you might have to block it off if your electric pump is pressure sensing cut off type.
blakep82
posted on 25/10/07 at 05:57 PM Reply With Quote
well, yeah... i mean not the bmw mini
NigeEss
posted on 25/10/07 at 06:50 PM Reply With Quote
Here you go, pumps
Or look for Facet at Demon Tweeks etc
snapper
posted on 25/10/07 at 07:06 PM Reply With Quote
take out any moving parts, or just the drive bit, use some fuel pipe to link the now redundant in and out and use a Facet pump.
I eat to survive
I drink to forget
posted on 25/10/07 at 07:46 PM Reply With Quote
Euro car parts should be able to supply the mechanical pump for less than 20 quid.
PURFLUX 339545010 PETROL PUMP AX BX14late C15E . £18.69
Really not a good idea to fit and electrc pump without a safety cut off switch
[Edited on 25/10/07 by britishtrident]
