Ben_Copeland
posted on 24/9/03 at 07:18 AM |
Wheel Nuts.. Escort/Sierra + Alloys
I have noticed that the MK1 escort axle i have fitted and the Sierra Front hubs have slightly different wheel nut / stud threads !!!??!?!
The Sierra wheels nuts go on the Escort studs, but not visa versa and the sierra nuts not 100% fit on the escort studs.
Now, i have just bought a set of capri alloys (7inch wide ones) and need a set of wheel nuts for these (cos the escort/sierra ones will not be any
use)....
What i'm wondering is will a set of capri wheel nuts fit on the sierra studs..... (the nuts will be the "special" ones with rotating
bit to stop damage to alloy) or will they be the same thread as the Escort studs and so not fit the sierra ???
Also why the hell did they change the thread in the first place ![](/images//smilies/mad.gif)
Ben_Copeland
posted on 24/9/03 at 07:22 AM |
I'm more likely to find a set of wheel nuts on a later ford with alloys..... so the likely hood is they will be the sierra thread ?????!!!!
Ben_Copeland
posted on 24/9/03 at 05:42 PM |
Is that possible ??? Which car can i nick the metric studs off ???? sierra is guess ??????
Ben_Copeland
posted on 24/9/03 at 05:46 PM |
ok mate cheers....
I'll give that a go... might pop down the breakers tomorrow and grap a few ![](/images//smilies/wink.gif)
Fast Westie
posted on 16/10/03 at 03:20 PM |
The studs on the Escort Mk1 axle are 1/2unf and on the Sierra 12x1.5mm, i.e. the don't fit. Change the rear studs for some metric ones from
Rally Design
The car in front is a Westfield
ned
posted on 16/10/03 at 03:25 PM |
Ben,
You can use the 'edit' button at the bottom of your post to add to your original post, no need for the one sided conversation then!
Ned.
beware, I've got yellow skin
Ben_Copeland
posted on 16/10/03 at 04:31 PM |
Hnmmmmm where did the other posts go ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
P.S. the sierra wheel nuts DO fit on Escort MK1 axle Even though the threads are slightly different.
Sod off Ned... someone's been deleting posts !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
