jabbahutt
posted on 31/10/07 at 08:02 AM |
pu adhesive and aluminium
Morning all
Quick question. Will PU adhesive bond aluminium to fibreglass well. I need in a couple of places to bond small non load bearing brackets to the
inside of the fibreglass and wondered if PU would do the job okay.
Many thanks
Nigel
Macbeast
| posted on 31/10/07 at 08:06 AM |
Probably. I might try fibreglass resin.
(wondering what a non load-bearing bracket would be for )
smart51
| posted on 31/10/07 at 08:07 AM |
My cycle wings are bonded to the powerder coated wing stays and have stayed put for 2 years now. It sticks to GRP very well.
My floor is PUed and riveted on and it hasn't come off either.
| posted on 31/10/07 at 08:36 AM |
As long as it's the proper stuff it should be fine... There's PU and PU
Strangely Tigerflex is listed as a sealant but is a very good adhesive. Usually it's the other way round- some adhesives are better used only as
sealants!!! I like the proper Sikaflex (can't remember to code number though!!)...
RazMan
| posted on 31/10/07 at 09:13 AM |
PU is practically designed for the job as it is flexible and won't break at the join (resin is too brittle for disimilar joins)
For a really strong bond I have found that windscreen adhesive is by far the best. Wurth make it I think.
Raz
Humbug
| posted on 31/10/07 at 09:15 AM |
"because you're Wurth it"?
| posted on 31/10/07 at 09:44 AM |
Like the proverbial ---- to a blanket in my experience
quadra
| posted on 31/10/07 at 01:02 PM |
If you use wurth adhesive then use gloves otherwise you will have black fingers for weeks.
Mike
You don't need eyes to see, you need vision!
