jabbahutt
posted on 8/11/07 at 08:33 AM |
will this do?
further to my earlier post on achieving a 5mm SVA okay radius on my dash. I got in the garage last night and tried various options from the bits and
bobs tray.
The easiest by far to fit was 15mm pre split convoluted tubing. If fitted so the inner bottom edge of the tubing was pressed up against the bottom
edge of the dash it's suprising strong when pressed.
How hard is the bottom edge press tested at SVA. If it's just a reasonable press I think the convoluted tubing will do and will look nice and
neat when covered.
Opinions please before I go further.
Bluemoon
posted on 8/11/07 at 08:40 AM |
Not sure but the convoluted stuff I have becomes brittle with time, also at a certain pressure it will crack. Last thing you want is the SVA man
cracking this as you will have to re-cover the dash for the re-test..
Dan
DaveFJ
posted on 8/11/07 at 08:46 AM |
Apparently it should be about the strength of a pencil eraser.....
I used a length of rubber tubing (actually from a door seal) and split it along it's length. I then filled it with PU adhesive and pushed it
on... once the adhesive had set it was going no-where and seems to give just the right level of padding.
Dave
brynhamlet
posted on 8/11/07 at 09:01 AM |
When my car failed for the bottom of the dash, the tester said it it had to be about the same or better than the Sierra wheel rim which I had fitted
at the time
jabbahutt
posted on 8/11/07 at 09:29 AM |
Many thanks all that's exactly the information I was after. Now I can try all sorts of different wall thickness of rubber hose etc to find one
with the pencil rubber/steering wheel squeeze resistance
Whilst on any tips for splitting hose quite neatly down a length without going off and partially round the hose? I tried a few test lengths last
night with a sharp blade and couldn't cut in a straight line to save my life on the curved surface
All tips and tricks to make it easier gratefully received.
DaveFJ
posted on 8/11/07 at 09:56 AM |
I used a good pair of scissors
Dave
posted on 8/11/07 at 10:15 AM |
are you the MDF dash or aluminium one?
if MDF, then I used t his sttuff:
I thinned the edge of the dash -using dremel - not easy as it was already fitted - the pu'ued the rubber edge on. Diagram below shows the idea -
it is impossible to feel any edge through the rubber trum.
![](/galpreviews/a643374-ld..JPG) ![Rescued attachment ld..JPG](/gallery/a643374-ld..JPG) Rescued attachment ld..JPG
jabbahutt
posted on 8/11/07 at 12:00 PM |
I'm the MDF dash one. Many thanks for the diagrams that explained everything really well and I know now which trim type from Woolies you used
as well.
Thanks to you all again for your assistance, seeing you have to look at the dash all the time it would be nice if it looked half decent.
gezer
posted on 8/11/07 at 12:51 PM |
could'nt you just glue a piece of narrow mdf along the bottom behind the dash say an inch wide or less to make it double thickness at the
bottom and radius that,?
I'm to old to live and to young to die --- buggerit
