Author: Subject: Gear Ratios ?
Volvorsport
posted on 11/11/07 at 12:28 PM Reply With Quote
Gear Ratios ?
are bike gear ratios like cars (obviously closer) ie they have a gear thats direct drive ie 1:1
www.dbsmotorsport.co.uk
getting dirty under a bus
Crazy Eddie
posted on 11/11/07 at 01:56 PM Reply With Quote
Have a look here might have info you need: Gearing
Eddie
www.EdwardsSchoolOfMotoring.co.uk
For online shopping that earns you money : Ei42.com
ChrisGamlin
posted on 11/11/07 at 02:10 PM Reply With Quote
Bikes engines dont generally get near a 1:1 ratio in relation to engine RPM and output shaft rpm, because they have a reduction ratio between the crank and the clutch, usually around 1.5:1 - 1.7:1.
Top gear itself is often around the 1:1 mark though in relation to the clutch RPM, which would obviously be ~ 1.5:1 if compared to the crank RPM.
Chris
[Edited on 11/11/07 by ChrisGamlin]
Bob C
posted on 11/11/07 at 03:40 PM Reply With Quote
also I think in general the output is effectively on the layshaft, so every ratio goes through 2 sets of cogs - 1) primary reduction and 2) selected gear
Volvorsport
posted on 11/11/07 at 04:18 PM Reply With Quote
so the output shaft spins faster than the engine , hmm that could work , teh othe rway round might scupper plans .
ChrisGamlin
posted on 11/11/07 at 07:45 PM Reply With Quote
Nope the other way around, the crank spins faster than the output shaft.
posted on 11/11/07 at 08:02 PM Reply With Quote
If the engine is spinning at 11,500rpm a 1:1 gear would give you top speed of about 240mph wouldn't it. That would be some car
Volvorsport
posted on 12/11/07 at 11:08 AM Reply With Quote
hmm i see , with a diff and small tyres , might be a bit less than 240mph !
im try to get this in front of some CVT belts , if i could id do away with the bike gearbox altogether , thats why i looked at BMW engines , but i dont think its gonna be possible .
might just have to junk the CVT bit .
[Edited on 12/11/07 by Volvorsport]
chrisf
posted on 12/11/07 at 01:36 PM Reply With Quote
Originally posted by Volvorsport
... thats why i looked at BMW engines , but i dont think its gonna be possible .
Not so. Have a look at the Yamaha RX-1. It is a snowmobile engine that is based on the R1 bike engine. It has slightly less horsepower than the bike engine, but also has the CVT standard. Were i brave enough or hand the machining tools at my disposal, I would have a go at a CVT car myself. Getting that CVT right would be tricky though.
--Chris
[Edited on 12/11/07 by chrisf]
