Author: Subject: Coil Pack connections + spare plug
Dave Bailey
posted on 11/11/07 at 09:01 PM Reply With Quote
Just got round to buidling my wiring harness and found that I do not have a connector to connect into the coil pack on my ST170 engine. I have all the other connections but not this one.. Anyone got a spare plus know which pin is which?
thanks
Dave B
MkIndy7
posted on 11/11/07 at 09:06 PM Reply With Quote
Can't help you with a spare plug, but if its the same as the Fiesta etc Ford coil packs.
As in the photo:
The left pin is sparks 2+3
Centre pin is an ignition live
Right pin is sparks 1+4
Dave Bailey
posted on 11/11/07 at 09:08 PM Reply With Quote
thanks
MkIndy7
posted on 11/11/07 at 09:13 PM Reply With Quote
Ooops EDIT EDIT EDIT
The left pin is spark output A, sparks 1+4
The right pin is spark output B, sparks 2+3
Diagram
Dave Bailey
posted on 11/11/07 at 09:38 PM Reply With Quote
O dear......too late connected it up to my £4000 race tuned engine and blew the lot.......caught fire and burn out my Porche in the adajacent garage also!..... must be some liability surely!
MkIndy7
posted on 11/11/07 at 09:48 PM Reply With Quote
Tut Tut
You should never work in the garage without a suitable Fire extinguisher to hand
... would have saved the Porche atleast
[Edited on 11/11/07 by MkIndy7]
big_wasa
posted on 12/11/07 at 06:43 AM Reply With Quote
Will have a look tonight for a spare
Dave Bailey
posted on 12/11/07 at 08:43 AM Reply With Quote
thanks
Dave B
desmo
posted on 13/11/07 at 07:47 AM Reply With Quote
I have a square connector on my wiring loop instead of an oval one. I got the same coil pack as you can see above. Does anyone know where I van find such a connector?
greetz,
Desmo
desmo
I have a square connector on my wiring loom instead of an oval one. I got the same coil pack as you can see above. Does anyone know where I can find such a connector?
greetz,
Desmo
[Edited on 13/11/07 by desmo]
mark-wiring
posted on 13/11/07 at 05:56 PM Reply With Quote
Later black top zetec engines use this type so look for a '99 on mondeo focus etc to be sure
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
