Author: Subject: Cortina Front Hub Torque Setting
davepro
posted on 19/11/07 at 12:30 PM Reply With Quote
Hi Guys
Does anybody have the correct torque setting for the front hub nut?
Thanks in advance
Dave
flak monkey
posted on 19/11/07 at 12:31 PM Reply With Quote
27lb-ft, then back off 90deg
Sera
http://www.motosera.com
twybrow
posted on 19/11/07 at 12:47 PM Reply With Quote
I am fairly sure it says something along the lines of checking the hub play and tighten accordingly. Certainly my hubs feel good and sturdy, and the torque required was about in the region FlakMonkey quoted.
Fatgadget
posted on 19/11/07 at 01:19 PM Reply With Quote
Yeah you do it by feel at the same time lining up the castle nut and stub axle hole for the best compromise between slack and tight.
Danozeman
posted on 21/11/07 at 10:02 AM Reply With Quote
Do it up tight and back off a flat or 2 of the nut.
Dan
