iiyama
posted on 19/11/07 at 09:14 PM |
Sierra stalk....again!
Im having trouble with the flash operation of the sierra stalk. Found that pin 56 is common and 56B is dip, 56A is main beam. However when I pull the
stalk for toward me for the passing light action I cant find this pin. I would have though that it will make pins 56 and 56A, however it dosent! And
more to the point I cant find the pin it does make to.
Im sort of drawing the conclusion that the switch is buggered. Anyone think the same? Or am I missing something? Wont be the first and Im sure it wont
be the last!!!
Edited to add that Im not using the light stalk, lights are switched on with Savage switches, one to turn on parking lights and another to fire up
dips.
[Edited on 19/11/07 by iiyama]
If its broke, fix it. If it aint broke, take it apart and find out how it works!
peterparsons
posted on 19/11/07 at 09:23 PM |
U2U sent
robbydee
posted on 19/11/07 at 09:24 PM |
http://www.cate1.co.uk/flash.html
i followed this and mine now works..
iiyama
posted on 19/11/07 at 09:43 PM |
Sorted!
Passing light action makes pins 15 and 56A
Thanks lads.
Ian
